Cad Translators - JT Out
2011-2-21 00:00| 查看: 43101| 评论: 0|来自: Siemens PLM Software
摘要: 软硬件环境/配置平台: INTEL操作系统: WINDOWS版本: XP64应用软件: ROBCAD版本: V9.0R问题/症状用户安装好Cad Translators 2.8 - the JT 导入是正常的,但是输出 JT 没有在菜单上找到。解决方法有一个"co2jt.exe ...
软硬件环境/配置
平台: INTEL
操作系统: WINDOWS
版本: XP64
应用软件: ROBCAD
版本: V9.0R
问题/症状
解决方法
有一个"co2jt.exe" 的程序在robcad\bin 的目录中;这可以在命令行中这样使用:
C:\Users\kliemann>co2jt -h
Usage:
co2jt <comp/cell/RF>
           [-output <output name>]
           [-dest <destination folder>]
           [-l <log file name>]
           [-f <batch convert text file>]
           [-library <component libraries folder>]
           [-keep]
           [-approx | -exact]
           [-noCurve]
           [-noPoint]
           [-noLocation]
           [-noFrames]
           [-monolithicJT]
           [-h | -?]
co2jt:           Converts Robcad cell/component/RF files to JT files.
comp/cell/RF:    Name (or names separated by space) of input
                 cell, component or robface (.RF) files.
-output: Specify the name of the output JT file.
-dest:           Specify a destination folder for the output files.
-l:              Specify the name of the log file.
-f:              Specify a file containing the names and parameters of the
                 input components/cells; <comp/cell> is not required.
-library:        Specify the library root component folder.
-keep:           Do not delete the intermediate robface file.
-approx: Convert as approximation.
-exact: Convert as exact geometry in XTBRep format (default).
-noCurve:        Exclude curves from the conversion.
-noPoint:        Exclude points from the conversion.
-noLocation:     Exclude locations from the conversion.
-noFrame:        Exclude frames from the conversion.
-monolithicJT:   Create monolithic JT assembly instead of per part assembly.
-h or -?:        Display extended usage.
GMT+8, 2026-7-12 11:52 , Processed in 0.028794 second(s), 7 queries , Gzip On, Redis On.
