【求助】剥鸡蛋壳的结构应该怎样做?
发表于 2004-11-4 11:40:32 | 只看该作者
luyun wrote:
While the eggs are boiling, she throws ice in a bowl, and adds water.  Once the eggs are done, the instructions tell us to place them in the ice water for at least ten minutes.
  The directions say, tap the small end of the egg on a plastic piercer, and the large end on a table.  Place it in the Eggstractor, and give on good fast push.
  使用说明:
  Place eggs in tap water, add salt. Make sure eggs are completely covered with water. Bring water to a full boil and then continue to boil for 6 -8 minutes!
  After boiling eggs carefully pour off the hot water and run cold water over eggs than...
  place eggs immediately in ICE WATER for a minimum of 10 minutes before Egggstraction.
  Tap small end of egg several times on the piercer located on the Eggstractor base.
  Piercer on Eggstractor Base. Make sure that you pierce through the inner layer of skin between shell and egg white.
  Crack the large end by tapping on table a couple of times. Make sure you fully crack large end of egg. Don抰 be timid!
  Make sure the small end of egg is facing upward when you place in base of Eggstractor
  Place egg in base small end pointed upwards (fat end in base ). Place Eggstractor over egg.
  Criss Cross hands over the top of the Eggstractor and give one good fast push. If egg did not pop out on the first try make sure you realign the egg in upright position before trying again.
前期步骤太复杂!
哪有卖,我去买一个!
262
发表于 2004-11-4 12:07:41 | 只看该作者
zjxfj wrote:
晕,蛋在放入之前的处理太复杂了,,,
  还要盐水煮,,冰水浸,,敲小头,破大头,,,无语了,,,放入还要注意是否垂直,,
  我建议大家把胃练好连壳吃算了,,没这么多事,,,,
  我开始还以为是一个熟的鸡蛋就这么放进去出来就裸奔了呢,,
深有同感!!
大家之所以討論這麼久沒有結果出來,原來是我們就沒有對具體的要求清楚,所以看了別人的東東後就有被強姦的感 覺 !
也正如所引用的一樣,沒想到在剝雞蛋以前還有如喲的講究,對一般人來說這個東東一點都不實用。
剛一開始我也以為隻要放一個煮熟的雞蛋一切都是這個機器搞定了,可惜它的前提條件太多了。
263
发表于 2004-11-5 19:40:17 | 只看该作者
这东西要是有人肯出钱,一定做得处,而且还不止一种方法.
264
发表于 2004-11-9 15:11:27 | 只看该作者
如果你能设计出来就可自已做老板了,再也不用给资本家卖命。
265
发表于 2004-11-12 06:33:24 | 只看该作者
DING !
266
发表于 2004-11-12 13:11:14 | 只看该作者
看了这贴,我有一个想法:
国外的产品是很好,可是他们的要求也很罗嗦,
而中国人的思维方式是简单化和感性化的
267
发表于 2004-11-12 13:35:28 | 只看该作者
高手云集呀!佩服
268
发表于 2004-11-12 21:01:35 | 只看该作者
不是有好的设计就万事大吉了,关键在转化. 有这样故事的人太多了.
剥蛋器之所以还没面世,主要的原因不是开发者不看好市场就是还有一些问题未解决.但我相信无论怎样我们现在入手都没意思了.
还有一个关于剥蛋器的构想供大家乐一乐,将鸡蛋壳切成一条螺旋线,象削苹果一样.效果如何只有试一下才知道.
关于剥蛋器的讨论我看可以休矣,它一定挂得太累了.
269
发表于 2004-11-13 09:43:10 | 只看该作者
用振盘把鸡蛋自动排列送入拨壳器内里面是十字型圆刀将蛋刻割成四份或两份用真空把蛋壳吸起放入废壳料斗送出再把蛋推入另一料斗很复杂有兴趣试试无防大概得五六万才可搞定!
270
发表于 2004-11-13 10:00:01 | 只看该作者
我有一个想法,就是在开始是,用刀片把鸡蛋壳“切”开,再用气压把壳吸开,这样就不用考虑蛋的大小,而且把蛋切一条口也与食用无关,不知行不??????细节就慢慢的设计
GMT+8, 2026-6-22 16:21 , Processed in 0.065961 second(s), 9 queries , Gzip On, Redis On.
