返回列表 发新帖
【求助】UF_UI_select_with_class_dialog的用法!!!
发表于 2006-6-26 09:56:05 | 只看该作者
Sample Text版主你好!我的出现: error C2065: 'UF_CALL' : undeclared identifier这个错误,下面是我得改回调函数内添加的程序:
int J_apply_cb ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     UF_STYLER_item_value_type_t data;
         int num_u,num_v;           //网格数控制
         char* option_string;
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
         data.item_id="NUM_U";
     data.item_attr=UF_STYLER_VALUE;
         UF_STYLER_ask_value(dialog_id,&data);
         num_u=data.value.integer;
     data.item_id="NUM_V";
         num_v=data.value.integer;
         data.item_id="OPTION";
     data.item_attr=UF_STYLER_SUBITEM_VALUES;
         option_string=data.value.string;
//         UF_STYLER_free_value;
//#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
         char cue[] = "Select Objects";
         char title[] = "User Title";
         int response, count, i;
         double face_param[2],face_point[3],face_u_deriv1[3],face_v_deriv1[3],face_u_deriv2[3];
         double face_v_deriv2[3],face_normal[3],face_radii[2];
         double face_max_curva[4],face_range[4];
         int face_curva_type[4];
         int p,j,k,m,n,h;
         int tt1=1;
     double mincvt,maxcvt,gauscvt;
         double uv_min_max[4];
         int uv_flag;
         int  isocurve_cnt;
         double parameter;
         double dist_tol=0.001;
     tag_t *isocurve_id;
         tag_t point;
         double u[1000],v[1000];          //划分网格的最大个数
//         int num_knot_u,num_knot_v,num_poles;
     tag_p_t objects;
         UF_MODL_bsurface_t bsurf;
         char buffer[133];
         int ii,jj,off=0;
         for(i=1;i<= num_u;i++)   //控制U向网格个数
                 u[0]=0;
                 u=u[i-1]+(double)1/num_u;
         for(i=1;i<= num_v;i++)   //控制V向网格个数
                v[0]=0;
                v=v[i-1]+(double)1/num_v;
        if((UF_CALL(UF_UI_select_with_class_dialog(
          cue, title, UF_UI_SEL_SCOPE_WORK_PART,
          NULL, NULL, &response, &count, &objects))) == 0)
                UF_UI_open_listing_window();
//                      sprintf(buffer,"response= %d, object count= %d\n",response,count);
//                    UF_UI_write_listing_window(buffer);
                if (response == UF_UI_OK && count > 0)
            for (p=0; p<count; p++)
                                UF_CALL(UF_MODL_ask_bsurf( objects[p], &bsurf ));
                                /* sprintf(buffer,"bsurf.order_u=%d,bsurf.order_v=%d,bsurf.num_poles_u=%d,bsurf.num_poles_v=%d,bsurf.is_rational=%d",
                                         bsurf.order_u,bsurf.order_v,bsurf.num_poles_u,bsurf.num_poles_v,bsurf.is_rational);
                                 UF_UI_write_listing_window("\n");
                                                   /* validate the surface */
                                for(m=0;m<=num_u;m++)
                                        face_param[0]=u[m];
                                        for(k=0;k<=num_v;k++)
                                                tt1=tt1+1;
                                                 face_param[1]=v[k];
                                                 UF_MODL_ask_face_props(objects[p],
                             face_param,
                             face_point,
                             face_u_deriv1,face_v_deriv1,
                             face_u_deriv2,face_v_deriv2,
                             face_normal,face_radii);
                                                 //***********************************添加求取曲率代码
                                                 face_range[0]=u[k];
                                                 face_range[1]=v[k];
                                                 UF_MODL_ask_max_curvature (
                                                         objects[p],
                                                         face_range,
                                                         response,
                                                         face_max_curva,
                                                         face_curva_type);
发表于 2006-6-26 15:01:48 | 只看该作者
我把UF_call去掉之后能够通过,但是在UG里面点击菜单没有反应阿
GMT+8, 2026-7-6 22:10 , Processed in 0.049542 second(s), 10 queries , Gzip On, Redis On.
