跪求解决方法。
6 h. P3 b' _3 \6 t8 l哪位高手能告诉我下面的一段config文件的命令怎样设置才能够真正的运作起来。5 I$ [5 A) J1 K# S/ e
意识就是每句都能实现他的应有的功能,还有关于环境变量怎么设置的$home,$Pro_Config_Dir 等问题* n2 M4 ?0 v3 ]8 j8 P6 D
跪求解答!!!!!
$ }6 L4 M- F* \8 R, X' N" ?6 t5 H+ Z: S$ L7 V
0 [1 f9 z. L! x% U: T) A!目录和文件设定 Directories & Files6 p( H2 A2 P* i2 W& g
! These are the path specific settings
5 k+ W3 ~( Y5 x; o! Note that some settings cannot accept environment variables.7 I' ~5 C2 s& Y3 K; V( d
8 O' i2 ]5 O8 Z) |!注:$home,$Pro_Config_Dir是操作系统环境变量,如系统环境变量中没有则应手工自已加,同加lang一样的添加方法
8 R1 K" P5 q7 U! T6 ]5 i2 O/ S!=========================================================* c" I$ u" d2 W& r3 ~
! SEARCH PATHS
' M8 ?6 q8 S7 i" p! Remove this section for use with Pro/INTRALINK5 i' t" z8 N- L( }+ }: s
!search_path .; Q5 Y, D! ^' R! a" h' _' s
!search_path $home/ E! W* E& z6 Q( | f
!search_path $Pro_Config_Dir/library_dir
9 r. N5 c7 {2 [; k' ~) n' V!search_path $Pro_Config_Dir/material_dir9 o5 k6 R3 x" P
!search_path $Pro_Config_Dir/group_dir$ K2 @9 x% \+ t% e
!search_path $Pro_Config_Dir/symbol_dir
7 E) s) U' @3 d6 A7 F* t6 n!search_path $Pro_Config_Dir/format_dir
# R B! W: N8 L: a4 | C!search_path $Pro_Config_Dir/start_files' g* z0 o2 _' c8 v
!=========================================================# L5 \& f# |. A, V+ g* Y
!texture_search_path $Pro_Config_Dir/texture_dir
Z! ]0 n z+ _2 ]: b!=========================================================5 J h* `, p( T$ F# f: y) o) P0 U
!bom_format $Pro_Config_Dir/configs/my_bom_style.fmt0 B+ y2 Z( I4 i4 o4 \% |( @
!campost_dir $Pro_Config_Dir/mfg_stds/campost
. S, Y+ q _7 {plot_file_dir $temp
2 ?! h" v. A/ e- V7 W4 ?* |* t
/ T0 U1 b2 P( x3 O& C: o! D
) e8 q6 G4 ^0 b: {. t0 ]# K5 s% Y: N9 Y- i1 F* H1 @
* m, L6 P M# J# `: M+ B& b7 d1 r |
