返回列表 发新帖
尋求UL94防火規格的資料
发表于 2004-9-11 12:38:33 | 只看该作者
UL 94 HB flammability standard(UL94 HB可燃性標準)
Specimen 試片
Length 125 mm (5 in) x Width 13 mm (0.5 in) x Thickness [typically 1.5 mm (1/16 in) or 3.0 mm (1/8 in) or 6.0 mm (1/4 in)].
長125mm(5")X寬13mm(1/2")X厚度[一般為1.5mm(1/16")、3.0mm (1/8")或6.0mm (1/4")厚]
Procedure 程序
Three specimens of each thickness are tested after conditioning for 48 hours at 23 degrees C and 50% RH.
每一種厚度準備了三個試片,測試前先在23℃和50%相對濕度下放置48小時。
Each specimen is mounted with its long axis horizontal and its short axis at a 45 degree angle.
每一試片以長軸呈水平、短軸呈45°方式固定。
Each specimen is marked with two lines, 25 mm and 100 mm from one end of the specimen.
每一試片在25mm及100mm處畫線做記號。
Each specimen is supported at one end such that its lower edge is 10 mm above a piece of wire gauze.
每一試片之一端固定,低緣下方10mm處水平放置一片金屬細網。
A 20 mm high blue Bunsen burner flame is applied to the free end of the specimen for 30 second and then removed. If the specimen continues to burn after the removal of the test flame, the time for the flame front to travel between the two gauge marks is measured and the burning rate calculated in millimeters per minute.
一個20mm高藍色本生燈火焰燃燒試片未固定之一端30秒鐘然後移開。 在火焰移開後假如試片繼續燃燒,則測出火焰由前緣燃燒至2個記號之間所用的時間。 燃燒速率以mm/min計算。
Requirements for HB HB等級的判定標準
The specimens may not have a burn rate exceeding 40 mm per minute over a 75 mm span for specimens having a thickness of 3.0 mm to 13 mm, or
3.0mm到13mm厚度之試片,沒有一個在75mn距離內燃燒速率超過40mm/min或
The specimens may not have a burn rate exceeding 75 mm per minute over a 75 mm span for specimens having a thickness less than 3.0 mm, or
小於3mm厚度之試片,沒有一個在75mm距離內燃燒速率超過75mm/min或
The specimens cease to burn before the flame reaches the 100 mm mark.
火焰在接近100mm記號前中止燃燒。
发表于 2004-9-11 15:50:19 | 只看该作者
楼上可将你的内容放在文件里在上载,皆大欢喜
发表于 2004-9-11 19:21:30 | 只看该作者
leouny wrote:
        是不是要看產品的使用環境來定﹐比如說家用電器﹐炸驢﹐吸塵器﹐消費性電子產品﹐他們用的環境不同﹐定的防火等級就不一樣。
是的,在同一个产品里,即使你用的是相同的材料,在不同部位(外壳、支架等)所要求的防火等级也不一样,离带电部件越近,其防火等级也就要求越高,因为带电部件是潜在火源。
发表于 2004-9-11 19:27:20 | 只看该作者
防火等级的高低顺序为:VA>V-0>V-1>V-2>HB,如果使用了HB的材料,除了要满足产品本身的标准外,还需要满足UL746的要求。现在有很多产品的外壳已经不允许使用HB等级的材料了。
发表于 2004-9-17 16:19:23 | 只看该作者
thanx
发表于 2004-10-26 17:55:16 | 只看该作者
3qs
发表于 2004-10-26 18:34:49 | 只看该作者
看我發的帖
gavinzg
GMT+8, 2026-6-20 00:17 , Processed in 0.056673 second(s), 10 queries , Gzip On, Redis On.
