返回列表 发新帖
【讨论】清华出的ug快速入门指导中的问题
发表于 2004-11-19 17:19:28 | 只看该作者
是的塞我就是刚学ug的呀,书上没的说的呀,快键不会呀,怎么设置呢?? 我对e文版的实在是郁闷的很,既然是小儿科,就请告诉我把!
发表于 2004-11-19 17:22:16 | 只看该作者
这个是我在这里找的快键,但是很多用不起,请问,怎么设置呢??高手就帮下菜鸟把!谢谢!
快捷目录如下:
Information listing created by : Administrator
Date : 2004-11-17 11:12:30
Current work part : E:\dsj\003_qinfeng\20pm_10.20\dwg\s.prt
Node name : cad
File-New... Ctrl+N UG_FILE_NEW
File-Open... Ctrl+O UG_FILE_OPEN
File-Save Ctrl+S UG_FILE_SAVE_PART
File-Save As... Ctrl+Shift+A UG_FILE_SAVE_AS
File-Plot... Ctrl+P UG_FILE_PLOT
File-Import-Part... Ctrl+1 UG_FILE_IMPORT_PART
File-Import-I-DEAS... Ctrl+7 UG_FILE_IMPORT_IDEAS_PART
File-Import-Parasolid... Ctrl+2 UG_FILE_IMPORT_PARASOLID
File-Import-NX-2D... Ctrl+8 UG_FILE_IMPORT_NX2D
File-Import-CGM... Ctrl+9 UG_FILE_IMPORT_CGM
File-Import-STL... Ctrl+0 UG_FILE_IMPORT_STL
File-Import-IGES... Ctrl+3 UG_FILE_IMPORT_IGES
File-Import-STEP214... Ctrl+4 UG_FILE_IMPORT_STEP214
File-Import-DXF/DWG... Ctrl+5 UG_FILE_IMPORT_DXF
File-Export-Part... Shift+1 UG_FILE_EXPORT_PART
File-Export-Parasolid... Shift+2 UG_FILE_EXPORT_PARASOLID
File-Export-CGM... Shift+9 UG_FILE_EXPORT_CGM
File-Export-JPEG... Shift+8 UG_FILE_EXPORT_JPEG
File-Export-TIFF... Shift+7 UG_FILE_EXPORT_TIFF
File-Export-IGES... Shift+3 UG_FILE_EXPORT_IGES
File-Export-STEP214... Shift+4 UG_FILE_EXPORT_STEP214
File-Export-DXF/DWG... Shift+5 UG_FILE_EXPORT_DXF
File-Export-2D Exchange... Shift+6 UG_FILE_EXPORT_UGTO2D
File-Execute UG/Open-Grip... Ctrl+G UG_FILE_RUN_GRIP
File-Execute UG/Open-Debug Grip... Ctrl+Shift+G UG_FILE_RUN_GRIP_DEBUG
File-Execute UG/Open-User Function... Ctrl+U UG_FILE_RUN_UFUN
Edit-Undo List-1 Open Part Navigator Ctrl+Z UG_EDIT_UNDO
Edit-Cut Ctrl+X UG_EDIT_CUT
Edit-Copy Ctrl+C UG_EDIT_COPY
Edit-Paste Ctrl+V UG_EDIT_PASTE
Edit-Delete... Ctrl+D UG_EDIT_DELETE
                                              Delete
Edit-Selection-Select General Objects G UG_SEL_GLOBAL_SELECTION
Edit-Selection-Select Sketch Objects S UG_SEL_SKET_OBJECTS
Edit-Selection-Select Features F UG_SEL_FEATURES
Edit-Selection-Select Components C UG_SEL_COMPONENTS
Edit-Selection-Select Constraints C UG_SEL_CONSTRAINTS
Edit-Selection-Select All Ctrl+A UG_SEL_SELECT_ALL
Edit-Blank-Blank... Ctrl+B UG_EDIT_BLANK_SELECTED
Edit-Blank-Reverse Blank All Ctrl+Shift+B UG_EDIT_REVERSE_BLANK_ALL
Edit-Blank-Unblank Selected... Ctrl+Shift+K UG_EDIT_UNBLANK_SELECTED
Edit-Blank-Unblank All of Part Ctrl+Shift+U UG_EDIT_UNBLANK_ALL_OF_PART
Edit-Transform... Ctrl+T UG_EDIT_TRANSFORM
Edit-Object Display... Ctrl+J UG_EDIT_OBJECT_DISPLAY
Edit-Sketch... Shift+K UG_EDIT_SKETCH
Edit-Curve-All... Shift+E UG_EDIT_CURVE_ALL
Edit-Curve-Trim... Shift+T UG_EDIT_CURVE_TRIM
Edit-Curve-Trim Corner... Shift+C UG_EDIT_CURVE_TRIM_CORNER
Edit-Curve-Divide... Shift+D UG_EDIT_CURVE_DIVIDE
Edit-Curve-Arc Length... Shift+A UG_EDIT_CURVE_ARC_LENGTH
Edit-Free Form Feature-Enlarge... Alt+Shift+L UG_MODELING_EDIT_FF_ENLARGE
View-Refresh F5 UG_VIEW_REFRESH
View-Operation-Fit Ctrl+F UG_VIEW_FIT
View-Operation-Zoom... Ctrl+Shift+Z UG_VIEW_ZOOM
View-Operation-Rotate... Ctrl+R UG_VIEW_ROTATE
View-Operation-Set WCS to Absolute O UG_WCS_SET_TO_ABS
View-Operation-Section... F3 UG_VIEW_SECTIONING
View-Visualization-Create Quick Image Ctrl+Shift+Q UG_VIEW_QUICK_IMAGE
View-Visualization-High Quality Image... Ctrl+Shift+H UG_VIEW_HIGH_QUALITY_IMAGE
View-Visualization-Face Edges F7 UG_VIEW_FACE_EDGES
View-Information Window F4 UG_VIEW_INFO_WINDOW
View-Curvature Graphs Ctrl+Shift+C UG_INFO_MB_SHOW_GRAPHS
Insert-Sketch... K UG_TOOLBOX_SKETCH
Insert-Curve-Basic Curves... B UG_CURVE_BASIC_CURVES
Insert-Curve-Spline... S UG_CURVE_SPLINE
Insert-Curve-Point... P UG_CURVE_POINT
Insert-Curve-Point Set... Q UG_CURVE_POINT_SET
Insert-Curve-Rectangle... R UG_CURVE_RECTANGLE
Insert-Curve-Polygon... Y UG_CURVE_POLYGON
Insert-Curve Operation-Offset... Shift+O UG_CURVE_OFFSET
Insert-Curve Operation-Bridge... Shift+B UG_CURVE_BRIDGE
Insert-Curve Operation-Simplify... Shift+M UG_CURVE_SIMPLIFY
Insert-Curve Operation-Join... Shift+J UG_CURVE_JOIN
Insert-Curve Operation-Project... Shift+P UG_CURVE_PROJECT
Insert-Curve Operation-Combined Projection... Shift+N UG_CURVE_COMBINE
Insert-Curve Operation-Intersect... Shift+I UG_CURVE_INTERSECT
Insert-Curve Operation-Section... Shift+S UG_CURVE_SECTION
Insert-Curve Operation-Extract... Shift+X UG_CURVE_EXTRACT
Insert-Curve Operation-Offset in Face... Shift+F UG_CURVE_OFFSET_FACE
Insert-Curve Operation-Wrap/Unwrap... Shift+W UG_CURVE_WRAP
Insert-Form Feature-Datum Plane... D UG_MODELING_DATUM_PLANE_FEATURE
Insert-Form Feature-Extrude... X UG_MODELING_EXTRUDED_FEATURE
Insert-Form Feature-Revolve... V UG_MODELING_REVOLVED_FEATURE
Insert-Form Feature-Extract... Alt+X UG_MODELING_EXTRACT_FEATURE
Insert-Feature Operation-Taper... T UG_MODELING_TAPER_FEATURE
Insert-Feature Operation-Edge Blend... Alt+E UG_MODELING_BLEND_FEATURE
Insert-Feature Operation-Face Blend... Alt+F UG_MODELING_FF_FACE_BLEND
Insert-Feature Operation-Soft Blend... Alt+B UG_MODELING_FF_SOFT_BLEND
Insert-Feature Operation-Chamfer... Alt+C UG_MODELING_CHAMFER_FEATURE
Insert-Feature Operation-Hollow... H UG_MODELING_HOLLOW_FEATURE
Insert-Feature Operation-Instance... I UG_MODELING_INSTANCE_FEATURE
Insert-Feature Operation-Sew... E UG_MODELING_SEW_FEATURE
Insert-Feature Operation-Simplify... Alt+M UG_MODELING_SIMPLIFY_FEATURE
Insert-Feature Operation-Offset Face... Alt+O UG_MODELING_OFFSET_FEATURE
Insert-Feature Operation-Scale... Alt+A UG_MODELING_SCALE_FEATURE
Insert-Feature Operation-Trim... Alt+T UG_MODELING_TRIM_FEATURE
Insert-Feature Operation-Split... Alt+P UG_MODELING_SPLIT_FEATURE
Insert-Feature Operation-Unite... Alt+U UG_MODELING_UNITE_FEATURE
Insert-Feature Operation-Subtract... Alt+S UG_MODELING_SUBTRACT_FEATURE
Insert-Feature Operation-Intersect... Alt+I UG_MODELING_INTERSECT_FEATURE
Insert-Free Form Feature-Through Points... Alt+Shift+P UG_MODELING_FF_THROUGH_POINTS
Insert-Free Form Feature-Ruled... L UG_MODELING_FF_RULED
Insert-Free Form Feature-Through Curves... U UG_MODELING_FF_THROUGH_CURVES
Insert-Free Form Feature-Through Curve Mesh... M UG_MODELING_FF_CURVE_MESH
Insert-Free Form Feature-Swept... W UG_MODELING_FF_SWEPT
Insert-Free Form Feature-Section... Alt+Shift+S UG_MODELING_FF_SECTION
Insert-Free Form Feature-Bridge... Alt+Shift+B UG_MODELING_FF_BRIDGE
Insert-Free Form Feature-N-Sided Surface... Alt+Shift+N UG_MODELING_FF_NSIDED
Insert-Free Form Feature-Extension... Alt+Shift+X UG_MODELING_FF_EXTENSION
Insert-Free Form Feature-Law Extension... Alt+Shift+W UG_MODELING_FF_LAWEXT
Insert-Free Form Feature-Offset... Alt+Shift+O UG_MODELING_FF_OFFSET
Insert-Free Form Feature-Rough Offset... Alt+Shift+R UG_MODELING_FF_ROUGH_OFFSET
Insert-Free Form Feature-Quilt... Alt+Shift+Q UG_MODELING_FF_QUILT
Insert-Free Form Feature-Swoop... Alt+Shift+P UG_MODELING_FF_SWOOP
Insert-Free Form Feature-Surface by 4 Points... Alt+Shift+4 UG_MODELING_FF_SURF4P
Insert-Free Form Feature-Studio Surface-1x1... Alt+1 UG_MODELING_FF_STUSRF_1X1
Insert-Free Form Feature-Studio Surface-1x2... Alt+2 UG_MODELING_FF_STUSRF_1X2
Insert-Free Form Feature-Studio Surface-2x0... Alt+3 UG_MODELING_FF_STUSRF_2X0
Insert-Free Form Feature-Studio Surface-2x2... Alt+4 UG_MODELING_FF_STUSRF_2X2
Insert-Free Form Feature-Studio Surface-nxn... Alt+5 UG_MODELING_FF_STUSRF_NXN
Insert-Free Form Feature-Styled Blend... Alt+Shift+Y UG_MODELING_FF_STYLED_BLEND
Insert-Free Form Feature-Global Shaping... Alt+Shift+G UG_MODELING_FF_OVERCROWN
Insert-Free Form Feature-Trimmed Sheet... Alt+Shift+T UG_MODELING_FF_TRIMMED
Insert-Free Form Feature-Fillet... Alt+Shift+F UG_MODELING_FF_FILLET
Insert-Free Form Feature-Midsurface... Alt+Shift+M UG_MODELING_FF_MIDSURFACE
Format-Layer Settings... Ctrl+L UG_LAYER_SETTINGS
Format-Visible in View... Ctrl+Shift+V UG_LAYER_VIEW
Format-Move to Layer... Ctrl+Shift+L UG_LAYER_MOVE
Format-Copy to Layer... Ctrl+Alt+L UG_LAYER_COPY
Format-Layout-New... Ctrl+Shift+N UG_LAYOUT_NEW
Format-Layout-Open... Ctrl+Shift+O UG_LAYOUT_OPEN
Format-Layout-Fit All Views Ctrl+Shift+F UG_LAYOUT_FIT_ALL_VIEWS
Tools-Expression... Ctrl+E UG_TOOLBOX_EXPRESSION
Tools-Macro-Start Record... Ctrl+Shift+R UG_MACRO_RECORD
Tools-Macro-Playback... Ctrl+Shift+P UG_MACRO_PLAYBACK
Tools-Macro-Step... Ctrl+Shift+S UG_MACRO_STEP
WCS-Origin... Alt+0 UG_WCS_ORIGIN
WCS-Rotate... Alt+9 UG_WCS_ROTATE
WCS-Orient... Alt+8 UG_WCS_ORIENT
WCS-Display Alt+7 UG_WCS_DISPLAY
WCS-Save Alt+6 UG_WCS_SAVE
Information-Object... Ctrl+I UG_INFO_OBJECT
Analysis-Distance... N UG_INFO_GEOMETRIC_DISTANCE
Analysis-Angle... A UG_INFO_GEOMETRIC_ANGLE
Preferences-Object... Ctrl+Shift+J UG_PREFERENCES_OBJECT
Preferences-Selection... Ctrl+Shift+T UG_PREFERENCES_SELECTION
Application-Modeling... Ctrl+M UG_APP_MODELING
Application-Drafting... Ctrl+Shift+D UG_APP_DRAFTING
Application-Manufacturing... Ctrl+Alt+M UG_APP_MANUFACTURING
Application-Assemblies Ctrl+Alt+W UG_APP_ASSEMBLIES
Application-Gateway... Ctrl+W UG_APP_GATEWAY
Help-On Context... F1 UG_HELP_ON_CONTEXT
Refresh F5 UG_VIEW_POPUP_REFRESH
Fit Ctrl+F UG_VIEW_POPUP_FIT
Update Display F6 UG_VIEW_POPUP_UPDATE
Display Mode-Wireframe F9 UG_VIEW_POPUP_WIREFRAME
Display Mode-Shaded F10 UG_VIEW_POPUP_FULLY_SHADED
Display Mode-Face Analysis F11 UG_VIEW_POPUP_SURFACE_ANALYSIS
Display Mode-Studio F12 UG_VIEW_POPUP_STUDIO
Orient View-Trimetric Home UG_VIEW_POPUP_ORIENT_TFRTRI
Orient View-Isometric End UG_VIEW_POPUP_ORIENT_TFRISO
Snap View F8 UG_VIEW_POPUP_SNAP_VIEW
发表于 2004-11-19 19:42:58 | 只看该作者
急。我这个好了,但是新问题出现拉!
预设置/可视化/调色板/编辑背景/把线框视图该为“平的” 把普通颜色该为“黑色” 就OK!了
就是现在层的颜色为绿色,我在上面画线,2唯的都是绿色的。可是一拉伸或直接用block等三唯的画,颜色总是姿色的,很难看,可怎么改都不行,怎么回事哦??有没的深圳的朋友呀,深圳那里有培训的,我要参加
发表于 2004-11-20 11:19:08 | 只看该作者
怎么没人回应呢/郁闷
GMT+8, 2026-6-17 22:02 , Processed in 0.069597 second(s), 9 queries , Gzip On, Redis On.
