返回列表 发新帖
[分享] 本公司洋工程师传授的General Design Guidelines教程,倾情奉献!
发表于 2006-5-31 12:27:07 | 只看该作者
Holes
Holes are easily produced in molded parts by core pins. Through holes are easier to produce than blind holes because the core pin can be supported at both ends.
Blind holes
Core pins supported by just one side of the mold tool create blind holes. The length of the pins, and therefore the depth of the holes, are limited by the ability of the core pin to withstand any deflection imposed on it by the melt during the injection phase. See information on bosses & cores.
As a general rule the depth of a blind hole should not exceed 3 times the diameter. For diameters less than 5 mm this ratio should be reduced to 2.
Through holes
With through holes the cores can be longer as the opposite side of the mold cavity can support them. An alternative is to use a split core fixed in both halves of the mold that interlock when the mold is closed. For through holes the length of a given size core can be twice that of a blind hole. In cases where even longer cores are required, careful tool design is necessary to ensure balanced pressure distribution on the core during filling to limit deflection.
Holes with an axis that runs perpendicular to the mold opening direction require the use of retractable pins or split tools. In some designs placing steps or extreme taper in the wall can avoid this. See section on draft. Core pins should be draw polished and include draft to help with ejection.
The mold design should direct the melt flow along the length of slots or depressions to locate weld lines in thicker or less critical sections. If weld lines are not permissible due to strength or appearance requirements, holes may be partially cored to facilitate drilling as a post molding operation.
The distance between two holes or one hole and the parts edge should be at least 2 times the part thickness or 2 times the hole diameter whichever is the largest.
For blind holes the thickness of the bottom should be greater than 20% of the hole diameter in order to eliminate surface defects on the opposite surface.  A better design is to ensure the wall thickness remains uniform and there are no sharp corners where stress concentrations can occur.
发表于 2006-5-31 12:31:13 | 只看该作者
斑竹,能不能帮忙加点分,以后我会为我们共同的事业---振兴中国的民族工业做出更大的贡献.
发表于 2006-6-4 10:20:06 | 只看该作者
一份好东东,大家都来支持一下.
发表于 2006-6-5 11:19:29 | 只看该作者
thanks
发表于 2006-6-5 11:22:41 | 只看该作者
早就有人发过了,不管怎么说!还是先谢了
发表于 2006-6-5 11:31:47 | 只看该作者
谢谢楼主分享
发表于 2006-6-5 14:40:20 | 只看该作者
好像和GE的设计指导有点类似。如果有什么特别是地方,能不能发份word档上来呀,那些图片在word里看着要方便些:)
GMT+8, 2026-6-24 10:59 , Processed in 0.057768 second(s), 10 queries , Gzip On, Redis On.
