[资料] 冲压模具设计资料
发表于 2006-7-4 21:32:16 | 只看该作者
好东东!
发表于 2006-7-5 12:24:25 | 只看该作者
TKS~~!
发表于 2006-7-10 00:06:29 | 只看该作者
我顶
发表于 2006-8-4 08:53:54 | 只看该作者
好资料!多谢分享!
发表于 2006-9-13 21:19:07 | 只看该作者
谢了先!
发表于 2006-9-25 21:22:12 | 只看该作者
tks
发表于 2006-11-5 04:33:00 | 只看该作者
附件: [冲压模具设计资料1] 冲模设计资料.rar (2006-6-23 15:32, 483.43 K)
该附件被下载次数 232
解压的.pdf用什么软件打开啊.谁知
发表于 2006-11-5 04:47:05 | 只看该作者
1.Use the Keygen.exe to generate your PTC HOST_ID license file;
2.Install the PTC License Server with your PTC HOST_ID license file which you got from Step 1;
3.Install Pro/ENGINEER, and select Single Server license type as the Pro/ENGINEER license;
  then fill "your computer name" as the HOSTNAME in the BLANK before the port "7788".
  *If you click the Setup Option" VERICUT (R) for Pro/ENGINEER" when you install Pro/ENGINEER and wanna the VERICUT as the
  *embedded software for pro/e, you should also do the following two steps for the embedded VERICUT:
  *    A. Copy the patched CGtech.dll into the installed directory \proeWildfire 3.0\i486_nt\obj to replace the original one.
  *    B. Find the following file in the installed directory \proeWildfire 3.0\bin\proev.bat and open it with an Editor software,
  *       search
  *          Vericut %argstr%
  *       and replace it with the following string:
  *          Vericut %argstr% PTC_KEY=0
  *       then save the file. the purpose of the step B. is to forbid the VERICUT to use the PTC lic as its lic.Actually, CGtech
  *       no longer supports its VERICUT as an embedded software for pro/e and no longer uses PTC lic.FYI, See the CGtech official
  *       website said:
  *            https://www.cgtech.com/ptc_update/index.htm
4.Install Pro/Mechanica(Structural and Thermal Simulation) like Step 3.
5.Install PTC Distributed Services.this step will automatically get the lic from the lic server installed at step 2.
6.That is all and enjoy it!
TEAM ZWT /2006
这是一篇安装pro.e3.0的破解,我把它汉化了,但是我看不懂,软件装完了,可是提示出错,望高手指点,多谢了
发表于 2006-11-5 07:41:09 | 只看该作者
我顶
20
发表于 2006-11-7 16:08:59 | 只看该作者
谢谢
GMT+8, 2026-6-21 02:22 , Processed in 0.067680 second(s), 12 queries , Gzip On, Redis On.
