查看: 18010|回复: 3
[新手求助] Pro/E的动态链接
发表于 2007-1-4 22:11:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
张继春的动态链接实例,代码输入编译后出现这样的问题:
F:\protoolkit\dll\PTC\MainPTC.cpp(22) : error C2146: syntax error : missing ';' before identifier 'TestAccessDefault'
F:\protoolkit\dll\PTC\MainPTC.cpp(22) : fatal error C1004: unexpected end of file found
原代码是这样的:
#include "ProToolkit.h"
#include "ProObjects.h"
#include "ProMdl.h"
#include "ProMenu.h"
#include "ProMenuBar.h"
#include "ProMessage.h"
#include "ProUtil.h"
#include "ProCore.h"
#include "ProParameter.h"
#include "ProModelitem.h"
#include "ProSolid.h"
#include "ProWindows.h"
#include "TestError.h"
#include "UtilMessage.h"
#include "TestEParams.h"
#include "import.h"
#include "stdafx.h"
#include "TestSect.h"
#include "UtilString.h"
static uiCmdAccessState TestAccessDefault(uiCmdAccessMode access_mode)
  return (ACCESS_AVAILABLE);
extern "C" void user_terminate()
extern "C" int user_initialize(int argc,char *argv[],
                                                           char *proe_vsn,char *build,wchar_t err_buff[])
  void *cmd_id;
  ProName wmsgfil;
  ProStringToWstring(wmsgfil,"utilities.txt");
  ProCmdActionAdd("gear1",(uiCmdCmdActFn)Load_Dlg,
        uiProe2ndImmediate,NULL,PRO_B_TRUE,
        PRO_B_TRUE,&cmd_id);
  ProMenubarmenuPushbuttonAdd("Utilities","gear","-Gear Design",
        "Gear Design help","Utilities.psh_util_aux",PRO_B_TRUE,cmd_id,wmsgfil);
  return (0);
void Load_Dlg()
  AFX_MANAGE_STATE(AfxGetStaticModuleState());
  Box* m_pBox=new Box();
  LoadDlg(m_pBox);
  ProMdl part;
  ProParameter param1;
  ProParameter param2;
  ProParameter param3;
  ProParameter param4;
  ProParamvalue value1;
  ProParamvalue value2;
  ProParamvalue value3;
  ProParamvalue value4;
  ProModelitem feature;
  int i;
  int teethnum1;
  double pitch1,angle1,width1;
  ProMdlRetrieve(L"E:\\ProE二次开发实用教程\\第五章\\5.2\\GEAR\\parts\\spur_gear.prt.1",PRO_MDL_PART,&part);
  ProMdlIdGet(part,&i);
  ProModelitemInit(part,i,PRO_PART,&feature);
  ProParameterInit(&feature,L"TEETH",&param1);
  ProParameterInit(&feature,L"PITCH",&param2);
  ProParameterInit(&feature,L"ANGLE",&param3);
  ProParameterInit(&feature,L"WIDTH",&param4);
  value1.type=PRO_PARAM_INTEGER;
  value1.value.i_val=m_pBox->c;
  value2.type=PRO_PARAM_DOUBLE;
  value2.value.d_val=1/m_pBox->m;
  value3.type=PRO_PARAM_DOUBLE;
  value3.value.d_val=m_pBox->y;
  value4.type=PRO_PARAM_DOUBLE;
  value4.value.d_val=m_pBox->k;
  ProParameterValueSet(&param1,&value1);
  ProParameterValueSet(&param2,&value2);
  ProParameterValueSet(&param3,&value3);
  ProParameterValueSet(&param4,&value4);
  ProSolidRegenerate((ProSolid)part,PRO_B_TRUE);
  ProMdlDisplay(part);
搞了很久查不出什么原因,请各位高手指点啊!
发表于 2012-4-12 21:52:42 | 只看该作者
发表于 2012-4-14 16:27:14 | 只看该作者
发表于 2012-4-14 22:25:34 | 只看该作者
GMT+8, 2026-8-12 23:20 , Processed in 0.046798 second(s), 11 queries , Gzip On, Redis On.
