【求助】请教家用电器、电脑外壳用的塑料?
发表于 2003-8-7 15:50:41 | 只看该作者
difyf wrote:
ABS757其中757是什么意思
台湾其美的牌号!
32
发表于 2003-8-29 13:22:35 | 只看该作者
qdzch wrote:
  已经禁止使用了!::y::y
怀疑很多公司还在用氟里昂发泡,特别是小公司和国内的公司。
33
发表于 2003-8-29 14:40:46 | 只看该作者
Above some is right some is wrong. If you have transparent parts you can use clear ABS, AS or SAN, PC, PP, HIPS,PMMA. ABS is good for composite feature. PC is good for mechanical and theormal performance.  SAN and PMMA is good for optics performance. But they are easy to break. PP is good for folding up, but it is soft usually. It is very cheap. HIPS can be used to instead of ABS if the impact requirement is not too high. If it is not clear. We can use ABS. PC. PC/ABS. PC/PS. If your product's elctric voltage is high you have to add some imflame additive. such as UL code. 94HB. V0., V5 etc. Like Epson's printer use HIPS but no inflame additive so that it was firing in Europe. Now it almost lost the whole Europe market.
GMT+8, 2026-6-23 03:15 , Processed in 0.055297 second(s), 10 queries , Gzip On, Redis On.
