查看: 28133|回复: 42
[原创] 发自己的源代码,支持的顶
发表于 2009-1-9 09:51:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
int SHEET_ok ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
    //变量申明
    char * sVariable="UGII_USER_DIR";
    char * sTranslation;
    char sSheetName[30]="";//视图名称
    UF_STYLER_item_value_type_t value;
    char sTemplatePath[255]="";//模板路径
    char sDTemplatePath[255]="";//标注模板
    int iSheetSelect=0;//图框选择
    char *sMillTemplate="\\application\\SheetTemplate\\A3_H_Mill.prt";
    char *sTurnTemplate="\\application\\SheetTemplate\\A3_H_Turn.prt";
    char *DraftingTemplate="\\application\\SheetTemplate\\template.prt";
    char buff[254]="";
    tag_t tPart_CurrPath;
    char sPart_Fspec[ 256 + 1 ];
    int  num_drawings;
    tag_p_t  drawing_tags;
    int                   mpi_array[100];
    double                mpr_array[70];
    char                  rad_symbol[27], dia_symbol[27];
    tag_t  part;
    UF_PART_load_status_t  error_status;
    tag_t  note_tag=NULL_TAG;
    double origin_3d[ 3 ]={57,-2.2,0};
    char * text_string[1];
    char str[254]="";
    UF_DRAW_info_t drawing_info;
    tag_t drawing_tag;
    drawing_info.drawing_scale=1;
    UF_import_part_modes_t modes;
        modes.layer_mode=0;
        modes.group_mode=1;
        modes.view_mode=0;
    double dest_csys[ 9],x_vec[ 3 ]={1,0,0},y_vec[ 3 ]={0,1,0};
    double dest_point[ 3 ]={0,0,0};
    tag_t  group ;
    drawing_info.units=UF_PART_METRIC;
    drawing_info.size_state=UF_DRAW_CUSTOM_SIZE;
    drawing_info.projection_angle=UF_DRAW_FIRST_ANGLE_PROJECTION;
    drawing_info.size.custom_size[0]=420;
    drawing_info.size.custom_size[1]=298;
    int SheetSign=0,PathSign=0,DraftingSign=0;
/********************************输入查询*********************************/
    //新图标识DraftingSign
     value.item_id=SHEET_NEW_DRAWING;
     value.item_attr=UF_STYLER_VALUE;
     UF_STYLER_ask_value (dialog_id, &value);
     DraftingSign=value.value.integer;
    //图框标识SheetSign
     value.item_id=SHEET_IMAGE;
     SheetSign=value.value.integer;
    //路径标识PathSign
     value.item_id=SHEET_PATH;
     PathSign=value.value.integer;
     //sprintf(buff,"%d;%d;%d",DraftingSign,SheetSign,PathSign);
     //uc1601(buff,1);
/********************************部件标识*********************************/
    tPart_CurrPath=UF_ASSEM_ask_work_part ( ); //获得当前工作部件标识
       UF_PART_ask_part_name (tPart_CurrPath,sPart_Fspec);  //查询部件路径
/********************************基本参数查询*********************************/
     //查询图框选择
     value.item_id=SHEET_SELECT ;
     iSheetSelect=value.value.integer;
     //取文件路径
     UF_translate_variable (sVariable, &sTranslation); //取环境变量
     strcpy(sTemplatePath,sTranslation);
     strcpy(sDTemplatePath,sTranslation);
     switch(iSheetSelect)
        {case 0: strcat(sTemplatePath,sMillTemplate); break;
         case 1: strcat(sTemplatePath,sTurnTemplate);  break;
         default: uc1601("图框选择错误!",1);
     strcat(sDTemplatePath,DraftingTemplate);
     //查询视图名字
     value.item_id=SHEET_NAME ;
     strcpy(sSheetName,value.value.string);
/*********************************功能选取*********************************/
/*********************************功能创建*********************************/
    UF_DRAW_ask_drawings (&num_drawings, &drawing_tags );
    //判断视图名称是否重复
    for(int i=0;i<num_drawings;i++){
        UF_OBJ_ask_name (drawing_tags, buff);
        if(strcmp(strupr(sSheetName),buff)==0){
            strcat(sSheetName,"_1");
            //uc1601(buff,1);
            i=0;
    UF_free (drawing_tags );
    //1:创建视图
    if(DraftingSign==1)
        UF_DRAW_create_drawing (sSheetName, &drawing_info, & drawing_tag );
    //2:导入图框
    if(SheetSign==1){
        UF_MTX3_initialize (x_vec, y_vec, dest_csys);
        UF_PART_import (sTemplatePath, &modes, dest_csys, dest_point, 1, &group );
    //3:设置标准模板参数
    UF_PART_open (sDTemplatePath, &part, &error_status );
    UF_DRF_ask_preferences (mpi_array,  mpr_array, rad_symbol, dia_symbol );
    UF_PART_close (part, 0, 1 );
    UF_PART_set_display_part (tPart_CurrPath );
    UF_DRF_set_preferences (mpi_array,  mpr_array, rad_symbol, dia_symbol );
    //4:创建路径标注
    text_string[0]=str;
    strcpy(str,"模型路径:");
    strcat(str,sPart_Fspec);
    if(PathSign==1)
        UF_DRF_create_note (1, text_string, origin_3d, 0, &note_tag );
    UF_terminate ();
    /* Callback acknowledged, terminate dialog             */
    /* It is STRONGLY recommended that you exit your       */
    /* callback with UF_UI_CB_EXIT_DIALOG in a ok callback.*/
    /* return ( UF_UI_CB_EXIT_DIALOG );                    */
    return (UF_UI_CB_EXIT_DIALOG);
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2009-1-9 09:53:57 | 只看该作者
发表于 2009-1-9 11:10:51 | 只看该作者
发表于 2009-1-9 11:11:07 | 只看该作者
发表于 2009-1-9 19:35:20 | 只看该作者
发表于 2009-1-9 20:27:03 | 只看该作者
发表于 2009-1-10 07:58:28 | 只看该作者
发表于 2009-5-4 20:57:58 | 只看该作者
头像被屏蔽
发表于 2009-5-4 21:19:37 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-5-7 19:55:43 | 只看该作者
GMT+8, 2026-8-3 10:12 , Processed in 0.063297 second(s), 11 queries , Gzip On, Redis On.
