查看: 24361|回复: 8
[求助] adams内存不足的问题
发表于 2009-3-13 16:42:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跪求,在view模块里我建的一个钢板弹簧,有点复杂,进行静力学仿真时没问题,进行动力学仿真时,提示内存不足,我改了一下设置,两种solver都试过,还是不行,下面是错误信息,请哪位大哥大姐帮帮忙啊?
ERROR:      ***** ADAMS MEMORY OVERFLOW *****
   A larger MD array is required.
   The error occurred in subroutine "SYMFAC" while allocating " DOUB" space
   from "SOLV" for the "Jacobian array".
   Space Available:  22764    Space Requested:  73802
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   10,000,000
        HUGE       20,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in ADAMS in words (one word is 4 bytes).
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
   Alternatively, you can start 'adams_settings.exe' in the 'utils\win32'
   folder of your ADAMS installation directory.
ERROR:   Abnormal termination encountered in ADAMS/Solver.
发表于 2009-3-13 16:46:55 | 只看该作者
发表于 2009-3-18 10:36:43 | 只看该作者
发表于 2009-8-6 20:21:17 | 只看该作者
发表于 2009-8-6 20:22:37 | 只看该作者
发表于 2010-4-25 14:08:34 | 只看该作者
发表于 2010-6-9 12:44:38 | 只看该作者
发表于 2010-7-4 14:34:36 | 只看该作者
发表于 2014-3-23 07:55:08 | 只看该作者
GMT+8, 2026-8-1 19:35 , Processed in 0.077190 second(s), 14 queries , Gzip On, Redis On.
