查看: 19152|回复: 8
[求助] 什么地方有CoCreate Part Library(零件库)下
发表于 2009-7-5 07:44:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位好!有谁知道什么地方有CoCreate Part Library(零件库)下?
或者有的朋友发EMAIL TO:33097770@qq.com
我用的是2008版本!谢谢了!
发表于 2009-7-7 10:10:00 | 只看该作者
发表于 2009-7-7 10:20:09 | 只看该作者
上面的连接是Kting提供,非常感谢他!
但装了还不能用,可能是安装方法问题。
希望会的朋友提供方法,谢谢了!
发表于 2009-7-16 09:29:00 | 只看该作者
我也想要零件库, 老大进来看看,PTC,已经开放下载,你就不必再记挂斑规了啊
请你出手,搞个08能用的零件库
发表于 2009-7-16 13:11:47 | 只看该作者
我现在电脑里装2007、2008版本。2008版本装不了零件库,没方法只有再装一个2007的版本。希望有高手过来解决!
发表于 2010-6-21 10:00:03 | 只看该作者
我电脑是装2007OSD.....有下載2007 Part Library 請問如何安裝2007 Part Library版本呢...
发表于 2010-6-30 21:32:52 | 只看该作者
安装方法:
CoCreate OneSpace 3D Library 2007 (version 15.50)
README
CoCreate Software GmbH
August 2007
Please Note:
CoCreate makes no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose.
CoCreate shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material.
This document contains proprietary information that is protected by copyright. All rights reserved.
No part of this document may be photocopied, reproduced, or translated into another language without the prior written consent of CoCreate.
Important Note for use of OneSpace 3D Library on Windows Vista
After installation of 3D Library on Windows Vista (32-bit or 64-bit editions), the administrator has to give full access rights to all users for directories
<catalog-installed>/slcatalog/dat
<catalog-installed>/slcatalog/prv
These full access rights are the prerequisite to use the 3D Library when being installed on Windows Vista.
In addition to that, the administrator has to give full access rights on Windows Vista (32-bit or 64-bit editions) to those users who will adapt configurations or catalogs for directories
<catalog-installed>/slcatalog/add
<catalog-installed>/slcatalog/ext
<catalog-installed>/slcatalog/lisp
<catalog-installed>/SolidLib/config
General Note for use of OneSpace 3D Library
When starting the 3D Library from the Modules menu in CoCreate OneSpace Modeling the configuration file sl_config has to exist in the 3D Library customization directory which is - by default - located in
C:\Documents and Settings\<user name>\Application Data\CoCreate\OSD_Modeling\<Modeling version>\SOLIDLIB
respectively (on Windows Vista)
C:\Users\<user name>\AppData\Roaming\CoCreate\OSD_Modeling\<Modeling version>\SOLIDLIB
Other possible locations of the customization directories can be found using
Modeling -> Edit -> Settings -> UI Settings -> Customizations -> Show Directories
Copy one of the files - dependent on the catalogs that are installed -
slansiso/sl_config
sldiniso_eng/sl_config
sldiniso_ger/sl_config
slexampl_eng/sl_config
slexampl_ger/sl_config
to the 3D Library customization directory.
Further information regarding the installation can be found in the Online Help of CoCreate OneSpace Modeling under "Installing 3D Library".
发表于 2010-6-30 21:39:05 | 只看该作者
先安装完后再到C:\Documents and Settings\<user name>\Application Data\CoCreate\OSD_Modeling\<Modeling version>\SOLIDLIB
上面路径中SOLIDLIB是创建的目录,然后再到安装后的文件目录里找sl_config ,将它COPY到SOLIDLIB目录中,就搞定了!
发表于 2010-9-1 14:23:20 | 只看该作者
有,但是没有目录,估计你要查找起来很头疼,我自用习惯了不需要目录
GMT+8, 2026-6-13 08:23 , Processed in 0.952649 second(s), 11 queries , Gzip On, Redis On.
