[教程] 宏:焊件切割清单中自动增加『单重』和『总重』的属性+3!(限額5位)
发表于 2014-11-22 10:11:45 | 只看该作者
zyf0732 发表于 2014-11-21 21:11
非常感谢闷大,闷大d宏稍加修改就能增加很多焊件自定义属性,终于知道相同焊件数量及切割项目名称值怎么获 ...
楼上既然成功扩展用途,可否分享出来让更说人受益。
322
发表于 2014-11-22 11:35:54 | 只看该作者
响应鹿大号召,我就是在闷大基础上增加了几个适合我的属性
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim Part As SldWorks.ModelDoc2
Dim thisFeat As SldWorks.Feature
Dim thisSubFeat As SldWorks.Feature
Dim cutFolder As Object
Dim BodyCount As Integer
Dim fn As String
Dim pn As String
Dim custPropMgr As SldWorks.CustomPropertyManager
Dim propNames As Variant
Dim vName As Variant
Dim propName As String
Dim Value As String
Dim resolvedValue As String
Dim TotalW As Double
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set thisFeat = Part.FirstFeature
Do While Not thisFeat Is Nothing
    If thisFeat.GetTypeName = "SolidBodyFolder" Then
        thisFeat.GetSpecificFeature2.UpdateCutList
    End If
    Set thisSubFeat = thisFeat.GetFirstSubFeature
    Do While Not thisSubFeat Is Nothing
        If thisSubFeat.GetTypeName = "CutListFolder" Then
            Set cutFolder = thisSubFeat.GetSpecificFeature2
        End If
        If Not cutFolder Is Nothing Then
            BodyCount = cutFolder.GetBodyCount
            If BodyCount > 0 Then
                Set custPropMgr = thisSubFeat.CustomPropertyManager
                If Not custPropMgr Is Nothing Then
                    custPropMgr.Delete "Total Weight"
                    custPropMgr.Delete "Weight"
                    custPropMgr.Delete "h名称"
                    custPropMgr.Delete "h数量"
                    custPropMgr.Delete "图号"
                    fn = thisSubFeat.Name
                    pn = Part.GetTitle
                    custPropMgr.Add "Weight", "文字", Chr(34) & "SW-Mass@@@" & fn & "@" & pn & Chr(34)
                    custPropMgr.Add "h名称", "文字", fn
                    propNames = custPropMgr.GetNames
                    If Not IsEmpty(propNames) Then
                        For Each vName In propNames
                            propName = vName
                            custPropMgr.Get2 propName, Value, resolvedValue
                            If propName = "Weight" Then TotalW = resolvedValue
                        Next vName
                    End If
                    custPropMgr.Add "Total Weight", "文字", Format(BodyCount * TotalW, "0.00")
                    custPropMgr.Add "h数量", "文字", BodyCount
                    custPropMgr.Add "图号", "文字", Left(pn, InStrRev(pn, ".") - 1) & "-"
                End If
            End If
        End If
        Set thisSubFeat = thisSubFeat.GetNextSubFeature
    Loop
    Set thisFeat = thisFeat.GetNextFeature
Loop
End Sub
不过这段程序没明白什么意思
                            propName = vName
                        Next vName
                    End If
还有请问各位大侠 能否把各个宏变都成按钮图标,用哪个就点哪个,不用再选择?
323
发表于 2014-11-22 15:22:49 | 只看该作者
顶起~~~~~~~~~~
324
发表于 2014-11-24 13:20:17 | 只看该作者
好贴必须顶
325
发表于 2014-11-24 19:29:02 | 只看该作者
很好的学习网站
326
发表于 2014-11-30 14:51:37 | 只看该作者
你这是如何引用的
327
发表于 2015-1-9 12:34:35 | 只看该作者
非常好,谢谢
328
发表于 2015-1-9 22:22:16 | 只看该作者
来学学看
329
发表于 2015-1-10 08:02:02 | 只看该作者
学习啊
330
发表于 2015-1-11 13:15:52 | 只看该作者
学习一下
GMT+8, 2026-6-28 19:31 , Processed in 0.064483 second(s), 13 queries , Gzip On, Redis On.
