查看: 17221|回复: 4
[原创] 发个GIBBS圆弧螺纹加工
发表于 2011-5-17 11:27:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  Requirements:
Make a round thread pattern for a 3/4" dia. rope on the O.D. of a round bar using a 1/2" dia. round insert.
Known values:
15" major dia.
14.25" minor dia.
Thread height = 3/8" per side (3/8" radius).
Insert = 1/2" dia. round (1/4" radius).
Procedure:
Determine the difference between the thread radius (3/8") and the tool radius (1/4").
Multiply this difference by two (because we're drawing in Dia. mode).
(3/8 - 1/4) x 2 = 1/4
Create a point at the start of the thread for "Z"  and at the major dia. for "X".  In this case, Z-3.58, X15.0.
Create a 1/4" dia. circle at that center point ( Z-3.58, X15.0).
Create a point at 3 O'Clock on that circle (Z-3.58 + .125 = Z-3.455).
*Select the point at 3 O'Clock and Modify, Duplicate and, 2D Rotate, 18 times @ 10Degs.
**Create a Thread Process for each point on the circle.
* I used 10 degs. to prove this out.  Use any angle/quantity combination necessary.
** 1) On the Thread Menu make sure the Major Dia. is set to 15".  2) Hi-light the Minor Dia. field and ALT+Click the point at 3 O'Clock to input it's value into the Minor Dia's. field.  3) Hi-light the starting "Z" field and ALT+Click the same point (-3.455).  4) Hi-light the ending "Z" field and ALT+Click the same point and then modify that value to represent the end of the thread (-3.455 - 7 = -10.455).  5) Subtract a 1/2" from the Minor Dia's. value to force the tool tip to the correct diameter ( Minor Dia. value - [1/4" TNR x 2].
I alternated the thread passes from leading edge to trailing edge of the thread for each dia. step in order to make balanced cuts.
发表于 2011-5-18 22:15:57 | 只看该作者
发表于 2011-5-22 12:32:39 | 只看该作者
发表于 2015-12-15 23:45:10 | 只看该作者
发表于 2016-8-28 18:38:55 | 只看该作者
GMT+8, 2026-8-12 09:16 , Processed in 0.124117 second(s), 12 queries , Gzip On, Redis On.
