查看: 13709|回复: 6
[原创] 显示法向方向
发表于 2013-6-24 20:44:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
extern DllExport void ufusr( char *parm, int *returnCode, int rlen )
    /* Initialize the API environment */
    if( UF_CALL(UF_initialize()) )
        /* Failed to initialize */
        return;
        double junk[3],start[3],tangent[3];
        tag_t curve;
        double cursor [ 3 ];
        tag_t view;
        int response;
        int scope=UF_UI_SEL_SCOPE_NO_CHANGE;
        UF_UI_select_with_single_dialog("小Z制造","小Z制造 ",scope,NULL,NULL,&response,&curve, cursor, &view );
        UF_DISP_set_highlight(curve,0);
        UF_MODL_ask_curve_props(curve, 0.0, start, tangent, junk, junk,junk, junk);
        UF_DISP_conehead_attrb_s attrb;
        int color=UF_OBJ_RED;
        UF_DISP_get_conehead_attrb(&attrb);
        attrb.color = color;
        UF_DISP_set_conehead_attrb(&attrb);
        UF_DISP_conehead(UF_DISP_ALL_ACTIVE_VIEWS, start,tangent, 0);
        UF_DISP_reset_conehead_attrb();
    UF_CALL(UF_terminate());
发表于 2013-6-29 14:53:32 | 只看该作者
发表于 2013-8-16 10:28:00 | 只看该作者
发表于 2013-8-20 16:54:12 | 只看该作者
发表于 2013-8-30 12:03:32 | 只看该作者
发表于 2013-9-16 22:41:17 | 只看该作者
发表于 2013-9-18 13:20:31 | 只看该作者
GMT+8, 2026-8-3 09:09 , Processed in 0.057709 second(s), 17 queries , Gzip On, Redis On.
