查看: 12432|回复: 3
[讨论] 关于NX连续打印图纸程序的源代码
发表于 2014-6-5 10:46:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
首先我要说明的是,打印程序和遍历文件夹程序都是网上找别人的,可是整合不好,所以发上来跟大家讨论讨论问题出在哪里
能遍历所有的文件了,就是只能打印第一个,打印第二个就会出错,所以可能问题是出在打印程序上,但是小弟实在不知道如何DEBUG,所以发上来跟大家探讨探讨
//先把打印功能写下来
        void print(TCHAR filefullpath[MAX_PATH])
{                 UF_PLOT_job_options_t    job_options;
                 UF_PLOT_banner_options_t banner_options;
                 char      *job_name;
                 int       copies;
                 tag_t         display_part;
                 tag_t         drawing_sheet;
                 UF_PART_load_status_t error_status;
                //然后判断当前是否有打开的prt
                display_part = UF_PART_ask_display_part();
                if (display_part == NULL_TAG)
                        /*return;*/
                //如果没有,则打开路径上的prt
            UF_PART_open(filefullpath,&display_part,&error_status);
         /*  If no part is displayed, do nothing.  */
                Get the default job options and banner options for use in
                the "print" call for each sheet
                UF_CALL( UF_PLOT_ask_default_job_options( &job_options) );
                UF_CALL( UF_PLOT_ask_default_banner_options( &banner_options ) );
                copies = 1;
                drawing_sheet = NULL_TAG;
                while ((UF_CALL(UF_OBJ_cycle_objs_in_part(display_part,
        UF_drawing_type,
        &drawing_sheet)) == ERROR_OK) &&
                           (drawing_sheet != NULL_TAG))
                         /*  Supplying a drawing sheet tag causes the default job
                                name to have the sheet name appended to it
          UF_CALL( UF_PLOT_ask_default_job_name( drawing_sheet, &job_name ) );
                        /*  Print the sheet. The "Printer One" printer MUST be
                                defined in the default Printer group for your system.
                                The "<System Profile>" profile is the default SDI
                                profile. You can alter these two parameters to match
                                your installation.
                        UF_CALL( UF_PLOT_print( drawing_sheet, &job_options, job_name,
        &banner_options, "PDFCreator",
        "A4", copies ) );
          UF_free( job_name );
发表于 2014-6-5 10:46:23 | 只看该作者
发表于 2014-6-5 10:46:44 | 只看该作者
发表于 2014-6-5 10:49:40 | 只看该作者
GMT+8, 2026-8-3 10:01 , Processed in 0.055821 second(s), 12 queries , Gzip On, Redis On.
