【讨论】EMX专栏
发表于 2002-11-2 12:07:30 | 只看该作者
我比较喜爱塑料模具,有哪位老兄能提供EMX的最新版本,谢谢!!!
tzclxs@pub.tz.jsinfo.net
32
发表于 2002-11-2 13:54:22 | 只看该作者
33
发表于 2002-11-2 15:39:39 | 只看该作者
請版主幫忙看一下,我在調入模胚時經常跳出。以下是調入時所顯示:Valid license for Expert Moldbase Extension 3.1 found!
Successfully changed to E:\gmb5\proe files\emx_ex1 directory.
Assembly components have absolute accuracy conflict. See file MOLD.ACC.
Processing model CAVITV ...
5% has been completed.
100% has been completed.
Processing model CORE ...
Current model is not a valid EMX-Assembly!
Ready!
Define the mold assembly...
Ready!
Ready!
Axes will not be displayed.
Datum point tags will not be displayed.
Datum points will not be displayed.
Coordinate Systems will not be displayed.
Datum planes will not be displayed.
Select an edge or curve to be measured.
Select first object.
Select second object.
Distance = 70.0000.
Distance = 70.0000.
Ready!
'MOLD' cannot be retrieved.
DATUM PLANE has been created successfully.
'cove_housing_1' cannot be retrieved.
...the system creates a new model...
'E:\gmb5\proe files\emx_ex1\COVE_HOUSING_1.drw.2' cannot be retrieved.
An error occured while loading models, abort!
Line 8 part COVE_HOUSING_1: Model changed since mass props calculated. May need to recalculate.
Line 10 part COVE_HOUSING_1: Invalid symbol 'BUW_ORD_NUMBER' found.
Cannot add ordering_number-relations
Part 'COVE_HOUSING_1' not changed since last regen.
COMPONENT has been created successfully.
'cove_ejbpl_mh1' cannot be retrieved.
'E:\gmb5\proe files\emx_ex1\COVE_EJBPL_MH1.drw.2' cannot be retrieved.
Line 1 part COVE_EJBPL_MH1: Model changed since mass props calculated. May need to recalculate.
Line 3 part COVE_EJBPL_MH1: Invalid symbol 'BUW_ORD_NUMBER' found.
Part 'COVE_EJBPL_MH1' not changed since last regen.
'cove_ejepl_mh1' cannot be retrieved.
'E:\gmb5\proe files\emx_ex1\COVE_EJEPL_MH1.drw.2' cannot be retrieved.
Line 1 part COVE_EJEPL_MH1: Model changed since mass props calculated. May need to recalculate.
Line 3 part COVE_EJEPL_MH1: Invalid symbol 'BUW_ORD_NUMBER' found.
Part 'COVE_EJEPL_MH1' not changed since last regen.
'cove_risers_mh1' cannot be retrieved.
'E:\gmb5\proe files\emx_ex1\COVE_RISERS_MH1.drw.2' cannot be retrieved.
Line 6 part COVE_RISERS_MH1: Model changed since mass props calculated. May need to recalculate.
Line 8 part COVE_RISERS_MH1: Invalid symbol 'BUW_ORD_NUMBER' found.
Part 'COVE_RISERS_MH1' not changed since last regen.
'cove_b_plate1' cannot be retrieved.
'E:\gmb5\proe files\emx_ex1\COVE_B_PLATE1.drw.2' cannot be retrieved.
Line 5 part COVE_B_PLATE1: Model changed since mass props calculated. May need to recalculate.
Line 7 part COVE_B_PLATE1: Invalid symbol 'BUW_ORD_NUMBER' found.
Part 'COVE_B_PLATE1' not changed since last regen.
'cove_a_plate1' cannot be retrieved.
'E:\gmb5\proe files\emx_ex1\COVE_A_PLATE1.drw.2' cannot be retrieved.
Line 1 part COVE_A_PLATE1: Model changed since mass props calculated. May need to recalculate.
Line 3 part COVE_A_PLATE1: Invalid symbol 'BUW_ORD_NUMBER' found.
Part 'COVE_A_PLATE1' not changed since last regen.
'cove_topclplate1' cannot be retrieved.
'E:\gmb5\proe files\emx_ex1\COVE_TOPCLPLATE1.drw.2' cannot be retrieved.
34
发表于 2002-11-2 15:42:22 | 只看该作者
不好意思!這麼長,裡面顯示了一些出錯的的條件:'cove_ejepl_mh1' cannot be retrieved.
'E:\gmb5\proe files\emx_ex1\COVE_EJEPL_MH1.drw.2' cannot be retrieved...
等等,不知是什麼原因?
35
发表于 2002-11-2 16:10:00 | 只看该作者
沒有這個模板文件COVE_EJEPL_MH1.drw.2 ,自己建一個試試!
36
发表于 2002-11-4 23:04:23 | 只看该作者
多謝版主指點。不過我還是不知道去怎樣補上這個文件。可否詳細一點說說。先謝謝!
37
发表于 2002-11-5 11:44:07 | 只看该作者
大家肯定都支持的,但关键在于普及EMX,这样我们的论坛才会不断壮大.
38
发表于 2002-11-5 13:58:15 | 只看该作者
支持建一个专栏
39
发表于 2002-11-5 15:30:22 | 只看该作者
开-开-开,我支持!!!!!!!
40
发表于 2002-11-6 12:39:34 | 只看该作者
真心希望高手门赶快上一些真的示例来,先将专栏搞活起来。
GMT+8, 2026-6-20 06:16 , Processed in 0.116823 second(s), 9 queries , Gzip On, Redis On.
