【求助】剥鸡蛋壳的结构应该怎样做?
发表于 2004-7-7 18:36:49 | 只看该作者
准备动作
182
发表于 2004-7-7 18:37:27 | 只看该作者
总体动作
183
发表于 2004-7-7 18:52:26 | 只看该作者
顶,还真有这东西啊!!
里面的结构是什么样的?
184
发表于 2004-7-7 18:56:48 | 只看该作者
While the eggs are boiling, she throws ice in a bowl, and adds water.  Once the eggs are done, the instructions tell us to place them in the ice water for at least ten minutes.
The directions say, tap the small end of the egg on a plastic piercer, and the large end on a table.  Place it in the Eggstractor, and give on good fast push.
使用说明:
Place eggs in tap water, add salt. Make sure eggs are completely covered with water. Bring water to a full boil and then continue to boil for 6 -8 minutes!
After boiling eggs carefully pour off the hot water and run cold water over eggs than...
place eggs immediately in ICE WATER for a minimum of 10 minutes before Egggstraction.
Tap small end of egg several times on the piercer located on the Eggstractor base.
Piercer on Eggstractor Base. Make sure that you pierce through the inner layer of skin between shell and egg white.
Crack the large end by tapping on table a couple of times. Make sure you fully crack large end of egg. Don抰 be timid!
Make sure the small end of egg is facing upward when you place in base of Eggstractor
Place egg in base small end pointed upwards (fat end in base ). Place Eggstractor over egg.
Criss Cross hands over the top of the Eggstractor and give one good fast push. If egg did not pop out on the first try make sure you realign the egg in upright position before trying again.
185
发表于 2004-7-7 19:00:34 | 只看该作者
不明白是怎么放进去的。
186
发表于 2004-7-7 19:04:52 | 只看该作者
俺不明白这是做啥用?
是过滤蛋壳还是....
187
发表于 2004-7-7 19:33:05 | 只看该作者
你是说图片左边的那个东西,那是个切蛋器,把剥好的蛋切成片。
188
发表于 2004-7-7 19:50:48 | 只看该作者
师傅留的作业,回去好好研究一下
189
发表于 2004-7-7 20:29:22 | 只看该作者
内部结构
190
发表于 2004-7-7 20:33:20 | 只看该作者
不符合我们的国情啊,国外的鸡蛋都是一般大小
GMT+8, 2026-3-27 17:24 , Processed in 0.061489 second(s), 9 queries , Gzip On, Redis On.
