查看: 15948|回复: 1
UG_POST OUTPUT "R" for FANUC
发表于 2004-4-7 20:47:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi, experts
    I am developing a postprocessor for FANUC 18M ....and got the following problems:
   for moom_circular_move, I want to output the "R" instead of "I J", I am using R[$mom_arc_radius], and the output in correct format. but the problem is:
   When I am doing a cicular movement whose sweep angle (A) is greater than 180, then the machine will just go along the small arc (360 -A), which will cause serious problem, and hurt the part.
  so, in this case, it is better to use R = -$R, using the negative R value.
  Then the problem comes: How can i decide the sweep angle is greater or smaller than 180?  I can not find a parameter available, and how can I do the calculation?
  In CLSF file of IDEAS, we can see the Sweep angle for a circular move, is there a similar one in UG ?
  Here is BLOCK:
  BLOCK_TEMPLATE circular_move
       G_cutcom[$mom_sys_cutcom_code($mom_cutcom_status)]\opt
       G_motion[$mom_sys_circle_code($mom_arc_direction)]\opt
       G_mode[$mom_sys_output_code($mom_output_mode)]
       X[$mom_pos(0)]
       Y[$mom_pos(1)]
       Z[$mom_pos(2)]
       R[$mom_arc_radius]
#        I[$mom_pos_arc_center(0) - $mom_prev_pos(0)]
#       J[$mom_pos_arc_center(1) - $mom_prev_pos(1)]
#       K[$mom_pos_arc_center(2) - $mom_prev_pos(2)]
       F[$feed]
#      S[$mom_spindle_speed]
   I am so worrying about this problem, Please advise as soon as possible!
  Thanks and have a nice day!
Best regards
发表于 2004-4-8 09:53:48 | 只看该作者
For more details, Please advise:
GMT+8, 2026-6-22 02:16 , Processed in 0.068679 second(s), 11 queries , Gzip On, Redis On.
