查看: 15974|回复: 3
UG二次开发中利用MFC动态链接库?
发表于 2004-5-21 09:51:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下程序中,为什么总是提示找不到ug的头文件(libufun.lib libugopenint.lib文件已加入到Projiect/Setting/link下),请版主和各路高手赐教!
#include "stdafx.h"
#include "www.h"
#include <uf.h>
#include <uf_exit.h>
#include <uf_ui.h>
#include <uf_styler.h>
#include <uf_part.h>
#include"MyDialog.h"
#include"Resource.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
BEGIN_MESSAGE_MAP(CWwwApp, CWinApp)
  //{{AFX_MSG_MAP(CWwwApp)
    // NOTE - the ClassWizard will add and remove mapping macros here.
    //    DO NOT EDIT what you see in these blocks of generated code!
  //}}AFX_MSG_MAP
END_MESSAGE_MAP()
CWwwApp::CWwwApp()
  // TODO: add construction code here,
  // Place all significant initialization in InitInstance
// The one and only CWwwApp object
CWwwApp theApp;
void DisplayDialog()
       AFX_MANAGE_STATE(AfxGetStaticModuleState());
       CMyDialog dlg;
       dlg.DoModal();
extern "C" DllExport void ufsta( char *param, int *returnCode, int rlen )
    int errorCode = UF_initialize();
     DisplayDialog ();
    if ( 0 == errorCode )
        errorCode = UF_terminate();
extern "C" void ufusr_cleanup(void)
extern "C"  int ufusr_ask_unload( void )
    return( UF_UNLOAD_UG_TERMINATE );
发表于 2004-5-21 21:49:08 | 只看该作者
发表于 2004-5-21 21:50:36 | 只看该作者
发表于 2004-5-22 07:31:36 | 只看该作者
GMT+8, 2026-8-4 00:47 , Processed in 0.054262 second(s), 11 queries , Gzip On, Redis On.
