查看: 16723|回复: 4
nx203_mp5
发表于 2004-7-3 03:42:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(Fixes from Unigraphics NX 2.0.3 cumulative patch, 11may04 version):
PR Number  &nbsproblem Description   Fixed Release
4863239   There was an incorrect tool axis that gouged the part under certain circumstances.   NX 3.0
4866842  Sequential mill post commands were not being output correctly.  NX 2.0.4
4879693  &nbsproblems occurred when converting LOAD/TOOL statements from v18 and NX 1.0 to NX 2.0.   NX 2.0.4
4888691  &nbspatterns specified for tool display could not be used on platforms other than the one on which they were defined.   NX 2.0.4
4897744   The Knowledge Fusion hostpointer value corresponding to a named object did not included the name of the object.  NX 2.0.4
4933056   Batch clearance analysis could not be run using the '-z' zones option.   NX 2.0.4
4935684, 4931038   The export of clearance results to a spreadsheet was using an invalid cell format for part names that began with numeric values.  NX 2.0.4
4936228, 4941542   GD&T display instances were being removed when doing part cleanup.   NX 2.0.4
4949788   Batch clearance analysis using zones was attempting to analyze occurrences outside the current zone of interest.  NX 2.0.4
4949873,
4596407  GD&T section curves reappear when changing component or pulling tolerances from Master Model.  NX 2.0.4
4950891, 4915171, 4951248   Multiple spindle statements not handled correctly.  Feed rate changed between v18 and nx2.   NX 2.0.4
4951590   Retract moves in surface contouring were erroneously being detected as gouges.   NX 2.0.4
4951862   Blank lines in user defined events caused other lines to be output twice.   NX 2.0.4
4970456   Memory was exhausted on certain true shape filtering operations.  NX 2.0.4
4953635, 4957889  &nbsparts List Fit method, Truncate option did not work.  NX 2.0.4
1300766  &nbspoor performance when customers have large number of variants configured in their database.   NX 2.0.4
1304065, 1290426, 4934153   The User settings for the Load Options were being overridden in Update Structure.   NX 2.0.4
1310589, 1326435,
1326760  Wrong database attributes were shown in Assembly Navigator.
See Note 1, below.  NX 2.0.4
1316660   The clone export dialog became corrupt after pressing Enter in the Checkout tab.  NX 2.0.4
1316667   Cannot exit from Tools, UG/Manager, Export Assembly dialog.  NX 2.0.4
1321192   Transformation with non-zero vector was incorrect when used while importing parts with tabular notes or parts lists.  NX 2.0.4
1322534, 1269388   Wrong sequence numbering in PSE when using family member selection criteria.  NX 2.0.4
1323458   Inserting a User Defined Feature with an extracted point caused an error in some cases.   NX 2.0.4
1324148, 4889227  A part name that contained ".asm" could not be saved using File, Save As.  NX 2.0.4
1324794   DXFDWG translator was not reading UG/Manager files.  NX 2.0.4
1325333   GRIP GPOS/ produced incorrect return values.   NX 2.0.4
1325672   In certain situation, attempt to open saved files caused Modeler error.   NX 2.0.4
1326435   Assembly Navigator is not displaying the synced Release_Status attribute of UGMASTER.  NX 2.0.4
1327333   Pre-NX1 parts with minor corruptions in solid faces failed to open in NX1 or NX2 due to a runtime error in conversion.  NX 2.0.4
1327914   Missing features after loading; KF features are deleted with no warning.  NX 2.0.4
2034055, 4933787   Drawing upgrade using refile_part did not work.  NX 2.0.4
2035478   Grip command &VWSEL does not return the correct view name after POS command.   NX 2.0.4
2036374   Hidden smooth silhouette edges with dashed hidden font disappear when updated.  NX 2.0.4
2036377, 1322759   Views update in the wrong order.   NX 2.0.4
4886511, 4925152   Repulling a GD&T datum using Master Model creates an incorrect callout.  NX 2.0.4
4898153   When opening drawing files they were being marked modified, dimensions were becoming retained and view dependent edits were lost.  NX 2.0.4
4900896, 4912910   When loading a V18 part, the default configuration (arrangement) becomes null causing an internal error.  NX 2.0.4
4920161   Translators fail to translate some lines in a detail view on a drawing.   NX 2.0.4
4927362   Internal error occurred and import failed if importing a CGM file resulted in more than 100 errors.   NX 2.0.4
4932367, 4966891   Assign and OK buttons not available for clone import with TcEng 9.0.   NX 2.0.4
4934192   Internal error was caused by pressing enter key in the date text field of load options pane of export assembly dialog.  NX 2.0.4
4935960   Clone assembly caused an Invalid file name error.  NX 2.0.4
4938116   Signal 11 occurs from uf5947 when occurrences are input.   NX 2.0.4
4939088   Hitting cancel on a KF/Application dialog could cause an undo error   NX 2.0.4
4941954   Interpart Expressions get deleted when using a Bookmark to load an assembly using the 'Load Interpart Data' load option.   NX 2.0.4
4948870   Memory access violation given when attempting selective export of an assembly. The assembly contains a part which has an altrep as an ancestor which is suppressed for the export.   NX 2.0.4
4953034   Can not import NX data to TcEng 9.1.0.3.   NX 2.0.4
4953212, 4863869   Error returned when instancing a group of features, i.e. UDF or Feature Set, which contained a Symbolic Thread feature.   NX 2.0.4
4954430   AIMS application did not work.   NX 2.0.4
4963527   When generating a tool path of a Holemaking operation a Signal 6 occurs. This only happened on the SUN platform   NX 2.0.4
4966891, 4967870, 4962277   'Part Type' reverted to non-active after user changed selection LOV.  Cannot clone import NX data to TcE P9.1.0.x with User Number option.   NX 2.0.4
4967033   Certain parts that have a corruption will not load.  NX 3.0
4970277   When AutoRouting an already routed set of connection list records, an internal error would occur.   NX 2.0.4
Additional fixes included in Maintenance Pack 5:
PR Number   Problem Description   Fixed Release
1325348  No component list was transferred to formboard.  NX 2.0.4
1325353, 4814125  Synchronization was not deleting components/segments in the formboard.  NX 2.0.4
4958430,
4975508  Wiring electrical auto route performance was slow.  NX 2.0.4
4961683  Placement solutions of ports with both rotate vector and engagement were not correct.  NX 2.0.4
1326392   When the non master was a read only file, while syncing the part list from the master a message appeared stating that the non master was a read only file.   NX 2.0.4
1326435,
1326760   Assembly Navigator was not displaying the correct values for the database attributes of the components.   NX 2.0.4
1327914   KF features were deleted without warning when NX 1.0 part was loaded.   NX 2.0.4
1328067   NX/Manager file caching was not correctly releasing files upon close.  NX 2.0.4
1329696   Problem with unnecessary KF rules created when a deformable component was deformed.  NX 2.0.4
4927067  Engine envelope operations caused unnecessary regeneration.   NX 2.0.4
4932217  Tire envelope feature will update to centerline shift.  NX 2.0.4
4935404  Negative offset values are now allowed in tire envelope.   NX 2.0.4
4935491  Revised text below sensitivity slider bar for tire envelope.  NX 2.0.4
4933260   Extruded Body preview bodies could cause Internal Errors.   NX 2.0.4
4938706   There was a performance problem with attributes on KF enabled UDF’s.  NX 2.0.4
4943194   Changing a layout with display suppressed, resulted in an internal error  NX 2.0.4
4948853   Incorrect GD&T Rules file used for GM 1994 addendum.  NX 2.0.4
4964909   Add support for export drawing and drawing instance checker NX/Open programs.  NX 2.0.4
4970456   True shape filtering operations in particular configurations (excessively small cell size, large components that lack true shape data) caused memory to be exhausted.  NX 2.0.4
4972908   Incorrect setting of LM_LICENSE_FILE variable blocked use of Scenario for Motion in some environments.  NX 2.0.4
1331965   Editing an expression through the UDF wizard, with the Expression Rule 'By Options' caused the message:
Error occurred while building wizard dialog.  NX 2.0.4
1292037, 1319696   There was a performance regression in SMD Metaform.  NX 2.0.4
1324085   Updating part family members via component properties dialog caused Internal errors.  NX 2.0.4
4909795   Section edge curves did not change layers when body was moved to different layer.   NX 2.0.4
4923361   Parts were marked as 'Modified' after saving and reopening.   NX 2.0.4
4959559   Update of child features of certain linked features failed.   NX 2.0.4
4989266  When working in NX/Manager CAM, configuration files could not be used.   NX 2.0.4
发表于 2004-7-3 08:12:38 | 只看该作者
发表于 2004-7-3 19:54:26 | 只看该作者
发表于 2004-7-3 21:08:18 | 只看该作者
发表于 2004-7-3 21:58:24 | 只看该作者
GMT+8, 2026-8-4 20:23 , Processed in 0.064402 second(s), 11 queries , Gzip On, Redis On.
