查看: 5818|回复: 17
[原创] 强迫症福音宏-集合同名零件
发表于 2020-8-10 15:05:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
改编自SOLIDWORKS API帮助中的例子"Move Assembly Components to New Folder Example (VBA)"
在原例基础上添加力遍历代码,在设计树中集合与选中零部件同名且同层的所有零件,移动到选中零件之后。
  1. Dim swApp As SldWorks.SldWorks
  2. Dim actDoc As SldWorks.AssemblyDoc
  3. Dim selectMgr As SldWorks.SelectionMgr
  4. Dim curFeature As SldWorks.Feature
  5. Dim targetComp As SldWorks.Component2
  6. Dim curComponent As SldWorks.Component2
  7. Dim parentComp As SldWorks.Component2
  8. Dim componentsToMove() As SldWorks.Component2
  9. Dim targetNameSplit() As String
  10. Dim count As Long
  11. Dim retVal As Boolean
  12. Dim featureName As String
  13. Dim featureType As String
  14. Dim targetName As String
  15. Dim compName As String
  16. Dim curCompName As String
  17. Sub Main()
  18.     Set swApp = Application.SldWorks
  19.     Set actDoc = swApp.ActiveDoc
  20.     Set selectMgr = actDoc.SelectionManager
  21.     Set targetComp = selectMgr.GetSelectedObjectsComponent4(1, -1) '获取选中零件
  22.     Set parentComp = targetComp.GetParent '获取父级零件
  23.     targetName = targetComp.Name2 '获取选中零件的层级名称
  24.     targetNameSplit = Split(targetName, "/") '分解层级名称
  25.     compName = targetNameSplit(UBound(targetNameSplit))
  26.     compName = Left(compName, InStrRev(compName, "-") - 1) '去除末端序号
  27.     count = 0
  28.     ReDim componentsToMove(count)
  29.     If parentComp Is Nothing Then '没有父级零件,代表是顶层零件
  30.         Set curFeature = actDoc.FirstFeature
  31.     Else
  32.         Set curFeature = parentComp.FirstFeature
  33.     End If
  34.     Do Until curFeature Is Nothing '循环到特征为空
  35.         featureName = curFeature.Name '获取特征名称
  36.         featureType = curFeature.GetTypeName2
  37.         If featureType = "Reference" Then '只选中零部件
  38.             curCompName = Left(featureName, InStrRev(featureName, "-") - 1) '去除末端序号
  39.             If curCompName = compName Then '筛选出同名零件
  40.                 retVal = curFeature.Select2(True, count + 1) '选中零件
  41.                 Set curComponent = selectMgr.GetSelectedObject6(count + 1, -1) '获取零件对象
  42.                 ReDim Preserve componentsToMove(count)
  43.                 Set componentsToMove(count) = curComponent '将零件存入数组
  44.                 count = count + 1
  45.             End If
  46.         End If
  47.         Set curFeature = curFeature.GetNextFeature() '选中下一个特征
  48.     Loop
  49.     retVal = actDoc.ReorderComponents(componentsToMove, targetComp, swReorderComponentsWhere_e.swReorderComponents_After) '将零件移动到指定零件后
  50. End Sub
复制代码
收藏收藏6 分享淘帖 赞一下!赞一下!
发表于 2020-8-11 13:52:14 | 只看该作者
求分享代码
发表于 2020-8-11 15:07:49 | 只看该作者
求分享
发表于 2020-8-11 17:34:49 | 只看该作者
装配体模型树排序宏的前身,鉴定完毕!
发表于 2020-8-12 08:54:42 | 只看该作者
xiaocake 发表于 2020-8-11 17:34
装配体模型树排序宏的前身,鉴定完毕!
我想对于镜像,阵列的零件就无效了
发表于 2020-8-12 14:02:00 | 只看该作者
羊三丫 发表于 2020-8-12 08:54
我想对于镜像,阵列的零件就无效了
阵列里面的零部件你还要排序???这强迫症得是啥境界了
发表于 2020-8-12 16:28:49 | 只看该作者
我想分享代码,但是却发不出来,好奇怪
发表于 2020-8-12 16:31:12 | 只看该作者
翻个墙出来就能插入代码发表了,这论坛以后不想来了
发表于 2020-8-13 08:38:38 | 只看该作者
前阵子这个网站的服务器估计崩溃了,无法访问,这两天可以登录了,但是我最后发的帖子丢了,太不靠谱了!!!
附件大小也限制得厉害,想发个动图都不行。。。
发表于 2020-8-31 15:22:50 | 只看该作者
甄云竹 发表于 2020-8-12 16:28
我想分享代码,但是却发不出来,好奇怪
大神可以帮我写一个更改切割清单名称的宏吗
GMT+8, 2026-6-13 14:34 , Processed in 0.072123 second(s), 10 queries , Gzip On, Redis On.
