查看: 1596|回复: 2
[讨论] 装配图中选中所有实体(solid bodies)的宏
发表于 2021-11-10 10:11:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是一个在装配或者零件环境下选中所有实体(solid bodies)的宏,不知道怎么回事,在我的SW2010下用不了,它总说,变量未定义,大家帮看下,是怎么回事。
This example shows how to select both solid and surface bodies in either a part or an assembly.
' Preconditions: Part or assembly is open.
' Postconditions: All solid and surface bodies are selected.
Option Explicit
Public Enum swDocumentTypes_e
    swDocNONE = 0       '  Used to be TYPE_NONE
    swDocPART = 1       '  Used to be TYPE_PART
    swDocASSEMBLY = 2   '  Used to be TYPE_ASSEMBLY
    swDocDRAWING = 3    '  Used to be TYPE_DRAWING
End Enum
Public Enum swBodyType_e
    swSolidBody = 0
    swSheetBody = 1
    swWireBody = 2
    swMinimumBody = 3
    swGeneralBody = 4
    swEmptyBody = 5
End Enum
Sub SelectBodies _
( _
    swApp As SldWorks.SldWorks, _
    swModel As SldWorks.ModelDoc2, _
    vBody As Variant, _
    sPadStr As String _
    Dim swModExt                    As SldWorks.ModelDocExtension
    Dim swBody                      As SldWorks.body2
    Dim sBodySelStr                 As String
    Dim sBodyTypeSelStr             As String
    Dim i                           As Long
    Dim bRet                        As Boolean
    If IsEmpty(vBody) Then Exit Sub
    Set swModExt = swModel.Extension
    For i = 0 To UBound(vBody)
        Set swBody = vBody(i)
        sBodySelStr = swBody.GetSelectionId
        Debug.Print "  " & sPadStr & sBodySelStr
        Select Case swBody.GetType
            Case swSolidBody
                sBodyTypeSelStr = "SOLIDBODY"
            Case swSheetBody
                sBodyTypeSelStr = "SURFACEBODY"
            Case Else
                Debug.Assert False
        End Select
        bRet = swModExt.SelectByID2(sBodySelStr, sBodyTypeSelStr, 0#, 0#, 0#, True, 0, Nothing, swSelectOptionDefault): Debug.Assert bRet
    Next i
End Sub
Sub ProcessComponent _
( _
    swComp As SldWorks.Component2, _
    nLevel As Long _
    Dim vChildComp                  As Variant
    Dim swChildComp                 As SldWorks.Component2
    Dim swCompConfig                As SldWorks.Configuration
    Dim sPadStr                     As String
    Dim vBody                       As Variant
    Dim i                           As Long
    For i = 0 To nLevel - 1
        sPadStr = sPadStr + "  "
    Next i
    Debug.Print sPadStr & swComp.Name2 & " <" & swComp.ReferencedConfiguration & ">"
    ' Solid bodies
    vBody = swComp.GetBodies2(swSolidBody)
    SelectBodies swApp, swModel, vBody, sPadStr
    ' Surface bodies
    vBody = swComp.GetBodies2(swSheetBody)
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        ProcessComponent swApp, swModel, swChildComp, nLevel + 1
    Next i
End Sub
Sub ProcessAssembly _
( _
    swModel As SldWorks.ModelDoc2 _
    Dim swConfigMgr                 As SldWorks.ConfigurationManager
    Dim swConf                      As SldWorks.Configuration
    Dim swRootComp                  As SldWorks.Component2
    Set swConfigMgr = swModel.ConfigurationManager
    Set swConf = swConfigMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent
    ProcessComponent swApp, swModel, swRootComp, 1
End Sub
Sub main()
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swPart                      As SldWorks.PartDoc
    Dim i                           As Long
    Dim bRet                        As Boolean
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    swModel.ClearSelection2 True
    Debug.Print "File = " & swModel.GetPathName
    Select Case swModel.GetType
        Case swDocPART
            Set swPart = swModel
            ' Solid bodies
            vBody = swPart2.GetBodies(swSolidBody, True)
            SelectBodies swApp, swModel, vBody, ""
            ' Surface bodies
            vBody = swPart.GetBodies(swSheetBody, True)
        Case swDocASSEMBLY
            ProcessAssembly swApp, swModel
        Case Else
            Exit Sub
    End Select
End Sub
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2021-11-10 10:54:37 | 只看该作者
发表于 2021-11-10 13:49:22 | 只看该作者
GMT+8, 2026-8-12 21:29 , Processed in 0.115061 second(s), 10 queries , Gzip On, Redis On.
