查看: 16735|回复: 4
图纸技术要求,哪位兄弟帮忙翻译一下,谢过先!!
发表于 2004-8-2 15:29:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Notes:Unless otherwise specified
1.  See bom for component part numbers and specifications
2.  Key characteristics to be monitored as vendor spc points data required nith each shipment
3.  Φ0.1262 min gage pin must drop thru both Φ0.1285 holes at the time
4.  This dimension applies to smallest Φ of punched holes to breax out (largest diameter) toward interior side . Maximum puncn to die clearance is 0.005 per side (0.010 on diameter)
5.  Burrs not to exceed 0.005 in height.
Notes:
2. &nbspart to be free of visible rust (when viewed from 24°under 40w fluorescent light-distance to light source 36°for 3 seconds)
3.  All exterior sharp corners may be R0.015 max
4.  This area to be burr-free
5.  Key characteristics see detail c
6. &nbspart to be clean, Free of oil, Grease and other contaminations.
发表于 2004-8-3 11:52:12 | 只看该作者
发表于 2004-8-4 14:04:24 | 只看该作者
发表于 2004-8-5 01:23:40 | 只看该作者
发表于 2008-9-9 22:47:31 | 只看该作者
GMT+8, 2026-8-24 10:12 , Processed in 0.060228 second(s), 11 queries , Gzip On, Redis On.
