查看: 16100|回复: 4
【灌水】请问斑竹是不是以前的帖子被删了?
发表于 2004-8-11 10:45:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
现在只剩下三页
还是放在什么地方了?
以前的东西
虽然不全是精华
但也不是垃圾阿
在此公布mcs专家对
WARNING: For TIRE JEEP.TIRE_1 the absolute value of the longitudinal slip ratio
has gone beyond its maximum allowable limit of 1.0.
Longitudinal slip ratio = 1.0021.
If the longitudinal slip ratio is positive, it will be set
to 1.0 (braking). If the longitudinal slip ratio is
negative, it will be set to -1.0 (traction).
的回复:
What you see is just a warning, not an error that will stop your simualtion. And with a ratio of only 1.0021, I would not be concerned if the resutls look ok. THe warning is just there to tell you that the slip will be set to one.
If you had a warning avout a ratio of 1000.0 I would be concerned, even though this often occurs (very, very common to see models where the chassis has a iniital velocity, but the tire spin velocity is not set; then the slip will initially be very larger; after half a second it is stablilized in most cases).
A ratio of 1.0021 could easily happen if you have a torque controller for braking. The little overshoot will generate the warning, but it does not affect the simualtion.
For most tire models this warning indicates that the tire contact area is saturated, i.e. the force will not change even if the slip gets larger. Therefore the slip is internally set to one.
希望做操稳的兄弟看到
头像被屏蔽
发表于 2004-8-12 09:21:48 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-8-12 15:04:14 | 只看该作者
发表于 2004-8-15 19:55:38 | 只看该作者
头像被屏蔽
发表于 2004-8-16 11:27:20 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2026-8-2 03:34 , Processed in 0.046963 second(s), 11 queries , Gzip On, Redis On.
