查看: 18654|回复: 18
【讨论】UG NX2.0 + MoldWizard NX2.0
发表于 2004-8-16 16:46:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在UG NX2.0 + MoldWizard NX2.0 里我在用 Create Pockets 给斜顶跟滑块建腔时,发现老是建不了腔,后来我用MoldWizard NX1.0.1G跟UG NX2.0结合后(也就是UG NX2.0 + MoldWizard NX1.0.1)再用 Create Pockets 给斜顶跟滑块建腔却一切OK.   Create Pockets 命令在WM1.0.1版本跟以前的版本用法都一样,然而到WM2.0后, Create Pockets命令完全改了,我按命令提示去做(用Create Pockets 给斜顶跟滑块建腔)竟然不行,大家试一试.
What’s New
Create Pockets
What is it?
The Create Pockets dialog has been changed to a selection steps style. In addition, new functionality has been added that displays the target components that intersect a selected standard component.
Why should I use it?
The new dialog provides you with tools to clearly see that the pockets are being created in the correct components.
Where do I find it?
Mold Wizard toolbar-> Create Pockets icon.
发表于 2004-8-16 16:53:14 | 只看该作者
发表于 2004-8-21 16:11:32 | 只看该作者
发表于 2004-8-21 19:06:05 | 只看该作者
发表于 2004-8-22 12:41:46 | 只看该作者
发表于 2004-8-22 21:10:20 | 只看该作者
发表于 2004-8-29 11:15:36 | 只看该作者
发表于 2004-8-30 08:25:26 | 只看该作者
发表于 2004-8-30 22:06:43 | 只看该作者
发表于 2004-8-30 22:14:59 | 只看该作者
GMT+8, 2026-8-16 19:13 , Processed in 0.066212 second(s), 11 queries , Gzip On, Redis On.
