查看: 17637|回复: 2
【求助】CAA运行case时遇到的问题
发表于 2004-9-19 22:49:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    按范例在Create/Update Runtime View…时,出现以下信息:
# mkmk-ERROR: Unable to load one or more module.data for framework [CAATPSInterfaces.edu].
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisBasicAppli.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisBasics.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisGeoModel.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisGeoModelInt.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisManagerAppli.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisManagerComp.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisManagerImpl.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisManagerInt.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisModelForRep.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisRep.m has no module.data associated.
# mkmk-ERROR: In framework CAAVisualization.edu module CAAVisWireBoxComp.m has no module.data associated.
# mkmk-ERROR: Unable to load one or more module.data for framework [CAAVisualization.edu].
# mkmk-ERROR: In framework CAAXMLParser.edu module CAAXMLDOMCreate.m has no module.data associated.
# mkmk-ERROR: In framework CAAXMLParser.edu module CAAXMLDOMTranscode.m has no module.data associated.
# mkmk-ERROR: In framework CAAXMLParser.edu module CAAXMLSAXCount.m has no module.data associated.
# mkmk-ERROR: In framework CAAXMLParser.edu module CAAXMLSAXResolver.m has no module.data associated.
# mkmk-ERROR: Unable to load one or more module.data for framework [CAAXMLParser.edu].
# mkmk-ERROR: In framework CAAxPDMInterfaces.edu module CAAxPDMController.m has no module.data associated.
# mkmk-ERROR: Unable to load one or more module.data for framework [CAAxPDMInterfaces.edu].
== Command done, return code = 0
Tool returned code: 0
请高手指点可能是什么原因?
而且我在Mkmk时对话框上总是显示:
...Connand done without
There is always didn't appear "errors"? WHY?
发表于 2004-9-20 14:38:25 | 只看该作者
发表于 2004-9-20 17:24:43 | 只看该作者
GMT+8, 2026-8-12 15:20 , Processed in 0.104321 second(s), 13 queries , Gzip On, Redis On.
