查看: 16535|回复: 0
【注意】catia v5R14 sp1 hotfix 3
发表于 2004-10-19 13:58:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
- This CD-ROM is the hotfix number 3 on SP1.
- Here is the list of problems that have been fixed since the first hotfix level.
- All of these corrections are present on the current CD-ROM.
- Level FUNCTION       APAR      Abstract
  HF1   PRISMACH       HD26809   PMG / TOOL AXIS DIRECTION REVERSE
  HF1   PRODEDIT       HD28240   Tech Package is allowed to change Approved TPEI document
  HF1   ITEV5CV5       HD28289   ProductDataGen Environment variable needs to be set correctly
  HF2   SYSTEM         HD26781   Run() method of the CATCGMOperator class has a memory leak when running the CATHybProject operator
  HF2   PRISMACH       HD27097   PMG PROFILE CONTOURING TOOL REVERSES AND JUMPS ALONG TOOL AXIS
  HF2   PRODEDIT       HD27209   PRODEDIT - EXPORTING AS AN XML FILE DOES NOT WORK . THE XML CANNOT BE DISPLAYED
  HF2   FREEFSHP       HD27618   FSS : The minimum radius value in Surfacic Curvature should be the one closest to 0
  HF2   CONFIG         HD28078   Multiple product specs affected by single product spec change
  HF2   AFLEDIT        HD28256   Production 7E7 Enovia vault locked up
  HF2   PRODEDIT       HD28491   PRODEDIT NOT ALL ATTRIBUTES ARE LISTED IN EXPORTED PRODUCT STRUCTURE
  HF3   QUERY          HD28458   Combined query filter Attribute Filter Configuration Filter Volume filter end up in an hung process.
  HF3   ITEV5CV5       HD28568   LCA Client consumes abnormally high cpu during SendToCATIAV5
  HF3   REVWMACH       HD26949   APIs of Machining Process instantiation
  HF3   OBJMOD         HD27498   CATIA couldn't start if CATMsgCatalogPath value is too long
  HF3   REVWMACH       HD28175   NC REVIEW / TOOL ASSEMBLY / INCORRECT BEHAVIOR AFTER CHANGING TOOL IN TOOL TAB PAGE
  HF3   FDT            HD28193   FTA : Different behaviour on 3D Anotation between R13 and R14GA
  HF3   CONFIG         HD28468   Incorrect computed effectivity on components of standard Product Instance
  HF3   GEOOPE         HD29066   NULPMRCAD00399: System-Down occurs in CATIntersectionSurSur::GetCurve() at R14SP01. (It[$#65407]s not occured in V5R14GA)
- Here is the list of files that will be fixed by the current CD-ROM:
81988     .\intel_a\code\bin\CATBBMagic.dll
168010    .\intel_a\code\bin\CATFamColorScale.dll
147533    .\intel_a\code\bin\CATFamSurfCurvature.dll
94280     .\intel_a\code\bin\CATFauSurfCurv.dll
2318415   .\intel_a\code\bin\CATFreeStyleResources.dll
7163983   .\intel_a\code\bin\CATGeometricOperators.dll
5320779   .\intel_a\code\bin\CATManufacturing1.dll
2728012   .\intel_a\code\bin\CATManufacturingUI.dll
475214    .\intel_a\code\bin\CATMilling3DToolPath.dll
389191    .\intel_a\code\bin\CATTPSAdapter.dll
41040     .\intel_a\code\bin\CATTPSPDMUESaveProcess.dll
24644     .\intel_a\code\bin\CATVersion.exe
217153    .\intel_a\code\bin\DataNav.dll
45120     .\intel_a\code\bin\ENOVIA.exe
57412     .\intel_a\code\bin\ENOVIPDSRV.dll
1826882   .\intel_a\code\bin\JS0GROUP.dll
24645     .\intel_a\code\bin\V5JsyEnvCpp.dll
24648     .\intel_a\code\bin\V5JsyEnvDotNet.dll
520263    .\intel_a\code\bin\VDP0OrbConfig.dll
2334786   .\intel_a\code\bin\VX0PSIMP.dll
2113      .\intel_a\docs\java\BBJumper.jar
10021     .\intel_a\docs\java\CATJsyClassLoader.jar
72092     .\intel_a\docs\java\GW0Start.jar
3755      .\intel_a\docs\java\PLBinitProxy.jar
38477     .\intel_a\docs\java\VDK0AlternatePart.jar
1372555   .\intel_a\docs\java\VDK0Appli.jar
180375    .\intel_a\docs\java\VDK0Document.jar
2938      .\intel_a\docs\java\VDK0Install.jar
226222    .\intel_a\docs\java\VDK0PartEditor.jar
308293    .\intel_a\docs\java\VDK0ProductClass.jar
47432     .\intel_a\docs\java\VDK0TechPack.jar
6045      .\intel_a\docs\java\VDK0VaultBatch.jar
203202    .\intel_a\docs\java\VDK0VaultServer.jar
80412     .\intel_a\docs\java\VDK0Zone.jar
24324     .\intel_a\docs\java\VaultJAVACORBA_S.jar
68359     .\intel_a\docs\javaserver\GW0Start.jar
3653      .\intel_a\docs\javaserver\PLBinitProxy.jar
2780      .\intel_a\docs\javaserver\VDK0Install.jar
5831      .\intel_a\docs\javaserver\VDK0VaultBatch.jar
72420     .\intel_a\docs\javaserver\VDK0VaultChecker.jar
191597    .\intel_a\docs\javaserver\VDK0VaultServer.jar
22760     .\intel_a\docs\javaserver\VaultJAVACORBA_S.jar
20999     .\intel_a\resources\msgcatalog\French\CATGeometricOperators.CATNls
8979      .\intel_a\resources\msgcatalog\VDA0OrbConfigMessages.CATNls
GMT+8, 2026-8-12 11:39 , Processed in 0.066343 second(s), 11 queries , Gzip On, Redis On.
