查看: 17484|回复: 2
【求助】五金英语术语 翻译一下,先谢了!
发表于 2004-11-1 08:43:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.  this specification covers requirements for tin coatings on fabricated
    articles of iron, steel, nickel alloys,copper and copper alloys to
    facilitate soldering, to improve antigalling characteristics and prevent
    corrosin.
2.  parts must be sealed in sulfur--free plastic bags with desicant to prevent
     oxidation/contamination of plated surface.
3.  bright tin plating including stannolume128, stannolume 160
4.  semi--bright tin plating including stannolume 128, semi--bright.
             (stannolume 128 with 50% reduction in brightness)
5.  matte tin plating including amtin 201.
6.  dull tin plating, including "splashless tin"
7.  unless otherwise specified on engineering drawings, type l plating to
     be used,
8.  all  of the above plating processes  must meet or exceed
     the repuirements of the following ASTM and MIL specifications
9.    plating surface should be free of contaminants
10.  service condition SC1 classification CU/SN5 or FE/SN5
11.  A plating process other than the above mentioned is used or
12.  when plating vendor is changed,also if existing vendor plating type changed,(e.g.type ll to type lll)
13.  To pualify a plating process. a manufacturing process approval will be required ,
14.   vendor should send a minimum of 5000, pieces with an outline of the plating
15.  process used; and a certificate of compliance accompanying shipment.
发表于 2004-12-1 16:43:49 | 只看该作者
这种资料也要翻译后再看吗?
发表于 2004-12-1 19:17:11 | 只看该作者
用金山词霸!
GMT+8, 2026-7-2 09:12 , Processed in 0.105532 second(s), 13 queries , Gzip On, Redis On.
