查看: 16408|回复: 2
請問各位前輩一個記憶體的問題?
发表于 2004-11-8 17:38:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
請問各位前輩..
不知有沒人使用過 lifemod ?
我建好人跟機構等等東西之後..我要執行inverse dynamic sumulation 的analyze...結果他跑出了下列的錯誤訊息:
ERROR:      ***** ADAMS MEMORY OVERFLOW *****
   A larger MD array is required.
   The error occurred in subroutine "ACPDOF" while allocating " INTE" space
   from "TEMP" for the "DOF temp array".
   Space Available:  6    Space Requested:  42
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   10,000,000
        HUGE       20,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in ADAMS in words (one word is 4 bytes).
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
          Start -> Programs -> ADAMS -> Settings
   Alternatively, you can start 'adams_settings.exe' in the 'utils'
   folder of your ADAMS installation directory.
ERROR:   Abnormal termination encountered in Solver.
請問各位前輩這是什麼回事呢?
還有..小弟暫時使用的是lifemod的試用版,不知跟這個有沒有什麼關係//
头像被屏蔽
发表于 2004-11-8 20:31:09 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-11-9 12:50:41 | 只看该作者
好强呢,以前都没有听说过,楼主有什么资料啊,分享一下吧
GMT+8, 2026-6-13 15:13 , Processed in 0.048241 second(s), 11 queries , Gzip On, Redis On.
