查看: 15986|回复: 3
【求助】斑竹看过来ug二次开发如何创建曲线?
发表于 2004-11-12 14:42:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   /* ---- Enter your callback code here ----- */
   int degree = 3;
   int periodicity = 0;
   int num_points = NUMBER_POINTS;
   double point1[3] = {-0.0539, 0.0511, 0.0000};
   double point2[3] = {-0.4801, 0.8428, 0.0000};
   double point3[3] = {2.0000, 0.9000, 3.5956};
   double point4[3] = {2.3456, 1.3456, 3.7890};
   double point5[3] = {3.1000, 2.4567, 3.3214};
   double slope1[ 3 ] = {0,0,0};
   double slope2[ 3 ] = {0,0,0};
   double slope3[ 3 ] = {0,0,0};
   double slope4[ 3 ] = {0,0,0};
   double slope5[ 3 ] = {0,0,0};
   double crvatr1[ 3 ] = {0,0,0};
   double crvatr2[ 3 ] = {0,0,0};
   double crvatr3[ 3 ] = {0,0,0};
   double crvatr4[ 3 ] = {0,0,0};
   double crvatr5[ 3 ] = {0,0,0};
   /* Point/slope curve attribute array */
   UF_CURVE_pt_slope_crvatr_t point_data[NUMBER_POINTS] =
       {  point1[3],
          UF_CURVE_SLOPE_AUTO,      slope1[ 3 ],
          UF_CURVE_CRVATR_NONE,     crvatr1[ 3 ]
       {  point2[3],
          UF_CURVE_SLOPE_NONE,      slope2[ 3 ],
          UF_CURVE_CRVATR_NONE, crvatr2[ 3 ]
       {  point3[3],
          UF_CURVE_SLOPE_NONE,      slope3[ 3 ],
          UF_CURVE_CRVATR_NONE,     crvatr3[ 3 ]
       {  point4[3],
          UF_CURVE_SLOPE_DIR,       slope4[ 3 ],
          UF_CURVE_CRVATR_VEC,      crvatr4[ 3 ]
       {  point5[3],
          UF_CURVE_SLOPE_VEC,       slope5[ 3 ],
          UF_CURVE_CRVATR_VEC,      crvatr5[ 3 ]
      {  {-0.0539, 0.0511, 0.0000},
      UF_CURVE_SLOPE_AUTO,      {0,0,0},
         UF_CURVE_CRVATR_NONE,     {0,0,0}
      {  {-0.4801, 0.8428, 0.0000},
         UF_CURVE_SLOPE_NONE,      {0,0,0},
      {  {2.0000, 0.9000, 3.5956},
      {  {2.3456, 1.3456, 3.7890},
         UF_CURVE_SLOPE_DIR,       {0,0,0},
         UF_CURVE_CRVATR_VEC,      {0,0,0}
      {  {3.1000, 2.4567, 3.3214},
         UF_CURVE_SLOPE_VEC,       {0,0,0},
  /* Arrays of user's defining point data */
   double parameters[NUMBER_POINTS] = {0.00, 0.89,  1.73,  2.23,  2.85};
   int i, save_def_data = 1;
   tag_t spline_tag;
   /* Create B-spline curve */
   UF_CURVE_create_spline_thru_pts(degree,
                                           periodicity,
                                           num_points,
                                       point_data,
                                           parameters,
                                           save_def_data,
                                           [$spline_tag)]
    UF_terminate ();
上面是我创建曲线的程序,如果直接输入点的值的话,可以创建曲线如程序里绿色的部分,但是我定义一个变量,然后把点的值赋值给变量,就不好使了,如程序中红色的部分,请问为什么。
发表于 2004-11-12 22:48:25 | 只看该作者
发表于 2004-11-13 08:11:39 | 只看该作者
发表于 2004-11-13 10:10:22 | 只看该作者
GMT+8, 2026-8-4 03:45 , Processed in 0.056516 second(s), 11 queries , Gzip On, Redis On.
