查看: 15611|回复: 2
PROE中的精度问题
发表于 2004-12-8 11:46:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在学模具设计的过程中遇到这个问题:
因为有细节出差不能生从MOLD VOLUM中生成PART,故改小了相对精度后能生成PART ,但不能生成MOLDING。系统提示精度有问题,以下是文件,请问大师怎么解决?
ccuracy Conflict Report For Assembly MFG0001.
1. Models in the list may have accuracy set to absolute or relative accuracy.
2. When the model's accuracy is relative, an absolute accuracy value
is calculated based on the model's relative accuracy.
3. The following list shows the absolute accuracy value for each model
that is actually used in geometry calculations.
       Generic Model Name           Abs Accuracy Value  Unit Name
MFG0001.ASM                           0.015339900       mm
MFG0001_REF.PRT                       0.005000000       mm
MFG0001_WRK.PRT                       0.013731906       mm
CAVITY-INSERT.PRT                     0.030679800       mm
CAVITY-INSERT-1.PRT                   0.030679800       mm
CAVITY-INLAY-1.PRT                    0.030679800       mm
CAVITY-INLAY-2.PRT                    0.030679800       mm
CORE-INSERT.PRT                       0.030679800       mm
CAVITY-INLAY-3.PRT                    0.030679800       mm
CAVITY.PRT                            0.030679800       mm
LIFT-M1.PRT                           0.030679800       mm
LIFTER-M2.PRT                         0.030679800       mm
CORE.PRT                              0.015317670       mm
发表于 2004-12-8 12:08:55 | 只看该作者
导到topsolid里面去试试看。可能有意外的收获。
发表于 2004-12-9 12:46:18 | 只看该作者
可修改绝对精度,使之一致。
GMT+8, 2026-7-2 07:54 , Processed in 0.060260 second(s), 11 queries , Gzip On, Redis On.
