查看: 16294|回复: 3
701590的问题
发表于 2005-1-18 00:16:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问各位大侠在分析时出现如下问题是什么原因,如何解决?  Cooling analysis type                              = Automatic
   Total number of part elements                      =       10294
   Total number of runner elements                    =          24
   Total number of mold elements                      =          68
   Total number of circuit elements                   =          68
   Co-ordinates of part extremity:
                        X             Y             Z
      Maximum        128.00600 mm     92.50000 mm      8.97000 mm
      Minimum       -128.00001 mm    -92.53390 mm    -52.03000 mm
      Orientation    384.01201 mm    277.53401 mm     69.97000 mm
** ERROR 701580 ** Orientation of two adjacent elements is inconsistent.
                   Angle between normals = 1.79805E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element    1402
** ERROR 701590 ** Check the orientation of element    8627
                   Angle between normals = 1.79861E+02 deg degrees.
** ERROR 701590 ** Check the orientation of element    8631
发表于 2005-1-18 09:37:34 | 只看该作者
发表于 2005-1-18 15:51:17 | 只看该作者
发表于 2005-4-22 13:16:43 | 只看该作者
GMT+8, 2026-7-28 01:46 , Processed in 0.054292 second(s), 11 queries , Gzip On, Redis On.
