查看: 16941|回复: 2
急急!!!大虾们过来看看吧!
发表于 2002-11-30 12:42:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
::6大虾们过来看看下面的内容吧!
具体参数是什么意思?怎么设置?小弟在此先谢了!
This file may be edited using available editor.Just type on the necessary lines appropriate values after the"="sign.Comments are not permitted on lines containing material properties names.
YOUNG-MODULUS=
POISSON- RATIO=
SHEAR-MODULUS=
MASS-DENSITY=
THERMAL-EXPANSION-COEFFICIENT=
THERMAL-EXPANSION-REF-TEMPERATURE=
STRUCTURAL-DAMLING-COEFFICIENT=
STRESS-LIMIT-FOR-TENSION=
STRESS-LIMIT-FOR-COMPRESSION=
STRESS-LIMIT-FOR-SHEAR=
THERMAL-CONCLUCTIVITY=
EMISSIUITY=
SPECIFIC-HEAT=
HARDNESS=
CONDITION=
INITIAL-BEND-Y-FACTOR=
BEND-TABLE=
PRO-UNIT-MASS=
PRO-UNIT-LENGTH=
PRO-UNIT-SYS=
发表于 2002-12-2 04:33:00 | 只看该作者
发表于 2002-12-8 11:43:07 | 只看该作者
GMT+8, 2026-8-4 04:50 , Processed in 0.056007 second(s), 11 queries , Gzip On, Redis On.
