查看: 15508|回复: 3
好奇怪的问题,高手们请指点迷津
发表于 2005-3-23 17:33:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在用proe打印的时候,笔宽的设置一直没有弄好
问题出在钣金件老是当细实线打了,我的table.pnt文件如下:
pen 1 color 0.0 0.0 0.0; thickness 0.4 mm;
pen 2 color 0.0 0.0 0.0; thickness 0.19 mm;
pen 3 color 0.0 0.0 0.0; thickness 0.19 mm;
pen 4 color 0.0 0.0 0.0; thickness 0.08 mm;
pen 5 color 0.0 0.0 0.0; thickness 0.4 mm;
pen 6 color 0.0 0.0 0.0; thickness 0.08 mm;
pen 7 color 0.0 0.0 0.0; thickness 0.08 mm;
pen 8 color 0.0 0.0 0.0; thickness 0.08 mm;
请高手们指点pen3,pen4,pen6,pen7,pen8中到底哪个是钣金绿线的宽度阿!
发表于 2005-3-23 17:35:09 | 只看该作者
而且观看了一些高手的帖子,虽然各有出入,但是都说pen5是设置钣金绿线的,可是我设置了,却还是细实线,有没有相同疑问的朋友啊?
发表于 2005-3-23 17:45:01 | 只看该作者
这个是我用的!
! This is a pen table file.  See Interface Guide under "pen mapping".
! Pen 1 = white entities (object lines)
! Pen 2 = yellow entities (text, dimensions, cross hatching)
! Pen 3 = gray entities (hidden lines)
! Pen 4 = red entities (can use for drawing border if you change the
! entity color to red in the format file)
! Pen 5 = green entities (sheetmetal)
! Pen 6 = cyan entities (section)
! Pen 7 = dark gray entities (dimmed)
! Pen 8 = blue entities (spline surface grid)
pen 1 thickness .025 cm; color 0 0 0
pen 2 thickness .015 cm; color 0 0 0
pen 3 thickness .015 cm; color 0 0 0
pen 4 thickness .020 cm; color 0 0 0
pen 5 thickness .025 cm; color 0 0 0
pen 6 thickness .025 cm; color 0 0 0
pen 7 thickness .015 cm; color 0 0 0
pen 8 thickness .025 cm; color 0 0 0
发表于 2005-3-23 18:13:11 | 只看该作者
Blue_star wrote:
这个是我用的!
谢谢
老兄,pen 5的笔宽我也改了呀,怎么还是不行呢
GMT+8, 2026-4-6 21:47 , Processed in 0.083822 second(s), 10 queries , Gzip On, Redis On.
