查看: 16005|回复: 3
请高手指点
发表于 2005-3-26 19:22:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我以用是用2001版的,现在刚用野火版,但界面全变了,好多以前用的命令都不知道哪里去了,哪位高手能告诉我一下吗?特别是曲线和曲面命令.急用!
发表于 2005-3-26 19:24:09 | 只看该作者
我以用是用2001版的,现在刚用野火版,但界面全变了,好多以前用的命令都不知道哪里去了,哪位高手能告诉我一下吗?特别是曲线和曲面命令.急用!我的QQ:410738133谢了.
发表于 2005-3-26 19:39:29 | 只看该作者
PRO/E部分命令对照LIST (PRO/E ProE2001  _to_wf2)
资料来源:https://www.ptc.com/community/proewf2/menu_mapper/en/index.htm
part (建模部分)
Wildfire 2.0 : Edit > Solidify
ProE2001   : Feature > Create > Solid > Cut > Use Quilt > Solid
Wildfire 2.0 : Edit > Thicken
ProE2001   : Feature > Create > Solid > Cut > Use Quilt > Thin
Wildfire 2.0 : Insert > Hole
ProE2001   : Feature > Create > Solid > Hole
Wildfire 2.0 : Insert > Variable Section Sweep
ProE2001   : Feature > Create > Solid > Cut > Advanced > Solid > Var Sec Swp
ProE2001   : Feature > Create > Solid > Protrusion > Use Quilt > Solid
ProE2001   : Feature > Create > Solid > Protrusion > Use Quilt > Thin
ProE2001   : Feature > Create > Solid > Protrusion > Advanced > Solid > Var Sec Swp
Wildfire 2.0 : Insert > Advanced > Radius Dome...
ProE2001   : Feature > Create > Solid > Tweak > Radius Dome
Wildfire 2.0 : Edit > Offset
ProE2001   : Feature > Create > Solid > Tweak > Offset
Wildfire 2.0 : Edit > Offset > Replace Surface Feature
ProE2001   : Feature > Create > Solid > Tweak > Replace
Wildfire 2.0 : Insert > Advance > Ear...
ProE2001   : Feature > Create > Solid > Tweak > Ear
Wildfire 2.0 : Insert > Advanced > Toroidal Bend
ProE2001   : Feature > Create > Solid > Tweak > Toroidal Bend
Wildfire 2.0 : Insert > Advanced > Spinal Bend
ProE2001   : Feature > Create > Solid > Tweak > Spinal Bend
Wildfire 2.0 : Insert > Advanced > Bend Solid
ProE2001   : Feature > Create > Solid > Tweak > Solid Bend
Wildfire 2.0 : Insert > Advanced > Flatten Quilt
ProE2001   : Feature > Create > Solid > Tweak > Flatten Quilt
Wildfire 2.0 : Insert > Sweep > Surface
ProE2001   : Feature > Create > Surface > New > Sweep
Wildfire 2.0 : Insert > Blend > Surface
ProE2001   : Feature > Create > Surface > New > Blend
Wildfire 2.0 : Edit > Fill
ProE2001   : Feature > Create > Surface > New > Flat
ProE2001   : Feature > Create > Surface > New > Offset
Wildfire 2.0 : Edit > Copy, Edit > Paste
ProE2001   : Feature > Create > Surface > New > Copy
ProE2001   : Feature > Create > Surface > New > Copy by Trim
Wildfire 2.0 : Insert > Round
ProE2001   : Feature > Create > Surface > New > Fillet
Wildfire 2.0 : Insert > Swept Blend > Surface
ProE2001   : Feature > Create > Surface > New > Advanced > Swept Blend
Wildfire 2.0 : Edit > Merge
ProE2001   : Feature > Create > Surface > Merge
Wildfire 2.0 : Insert > Extrude
ProE2001   : Feature > Create > Surface > Trim > Extrude > Solid
Wildfire 2.0 : Insert > Sweep > Surface Trim
ProE2001   : Feature > Create > Surface > Trim > Sweep > Solid
Wildfire 2.0 : Edit > Trim
ProE2001   : Feature > Create > Surface > Trim > Use Quilt > Solid
ProE2001   : Feature > Create > Surface > Trim > Use Curves
Wildfire 2.0 : Insert > Advanced > Silhouette Trim
ProE2001   : Feature > Create > Surface > Trim > Vertex Round
ProE2001   : Feature > Create > Surface > Trim > Silhouette
ProE2001   : Feature > Create > Surface > Trim > Advanced > Solid > Var Sec Swp
Wildfire 2.0 : Edit > Extend
ProE2001   : Feature > Create > Surface > Extend
Wildfire 2.0 : Edit > Copy, Edit > Paste Special
ProE2001   : Feature > Create > Surface > Transform > Move
Wildfire 2.0 : Edit > Mirror
ProE2001   : Feature > Create > Surface > Transform > Mirror
Wildfire 2.0 : Edit > Flip Normal...
ProE2001   : Feature > Create > Surface > Transform > Flip Normal
Wildfire 2.0 : Insert > Draft
ProE2001   : Feature > Create > Surface > Draft
ProE2001   : Feature > Create > Surface > Area Offset
ProE2001   : Feature > Create > Surface > Draft Offset
Wildfire 2.0 : Insert > Shared Data > Copy Geometry from Other Model
ProE2001   : Feature > Create > Data Sharing > Ext Copy Geom
Wildfire 2.0 : Insert > Shared Data > Merge from Other Model
ProE2001   : Feature > Create > Data Sharing > Ext Merge
Wildfire 2.0 : Insert > Shared Data > Cutout from Other Model
ProE2001   : Feature > Create > Data Sharing > Ext Cutout
Wildfire 2.0 : Edit > Feature Operations > Copy
ProE2001   : Feature > Copy
Wildfire 2.0 : Edit > Feature Operations > Group
ProE2001   : Feature > Group
Wildfire 2.0 : Edit > Resume
ProE2001   : Feature > Resume
Wildfire 2.0 : Edit > Read Only
ProE2001   : Feature > Read Only
Wildfire 2.0 : Select the Part name in the Model Tree > Edit > Mirror
ProE2001   : Feature > Mirror Geom
Wildfire 2.0 : Edit > Value
ProE2001   : Modify > Value
Wildfire 2.0 : Edit > Properties
ProE2001   : Modify > Dimension
Wildfire 2.0 : View > View Manager > Simp Rep > New
ProE2001   : Simplfd Rep > Create
Wildfire 2.0 : Edit > Regenerate
ProE2001   : Regenerate
Wildfire 2.0 : Tools > Relations
ProE2001   : Relations
Wildfire 2.0 : Edit > Setup > Units
ProE2001   : Set Up > Units
ProE2001   : X-section
Assembly (组件部分)
Wildfire 2.0 : Insert > Component > Assemble
ProE2001   : Component > Assemble
Wildfire 2.0 : Insert > Component > Create
ProE2001   : Component > Create
Wildfire 2.0 : Edit > Definition
ProE2001   : Component > Redefine
Wildfire 2.0 : Edit > Replace
ProE2001   : Component > Adv Utils > Replace
Wildfire 2.0 : Edit > Component Operations > Merge
ProE2001   : Component > Adv Utils > Merge
Wildfire 2.0 : Edit > Component Operations > Cut Out
ProE2001   : Component > Adv Utils > Cut Out
Wildfire 2.0 : Insert > Component > Include
ProE2001   : Component > Adv Utils > Include
Wildfire 2.0 : Edit > Component Operations > Group
ProE2001   : Component > Adv Utils > Group
Wildfire 2.0 : Edit > Activate
ProE2001   : Modify > Mod Part
Wildfire 2.0 : View > View Manager > Explode
ProE2001   : Explode State
Drawing (工程图部分)
Wildfire 2.0 : Insert > Drawing View
ProE2001   : View > Add View
In Pro/ENGINEER Wildfire 2.0, all Drawing View related menu managers have been consolidated into a new, easy to use dialog that gives you visual feedback while you are defining or modifying drawing views. As you advance from section to section, the view on the drawing sheet updates to your latest change. The Drawing View dialog is activated when a new drawing view is created or when an existing drawing view is modified.
Wildfire 2.0 : Click on View and Drag [RMB > Make sure Lock View Movement is unchecked]
ProE2001   : View > Move View
Wildfire 2.0 : Edit > Properties or Double Click a View
ProE2001   : View > Modify View
Wildfire 2.0 : Edit > Delete
ProE2001   : View > Delete View
Wildfire 2.0 : Edit > Group > Relate to View
ProE2001   : View > Relate View
Wildfire 2.0 : Edit > Properties > View Display section of Drawing View dialog
ProE2001   : View > Disp Mode > View Disp
Wildfire 2.0 : View > Drawing Display > Edge Display
ProE2001   : View > Disp Mode > Edge Disp
Wildfire 2.0 : View > Drawing Display > Component Display
ProE2001   : View > Disp Mode > Member Disp
Wildfire 2.0 : File > Properties > Drawing Models
ProE2001   : View > Dwg Models
Wildfire 2.0 : File > Properties > Drawing Options
ProE2001   : Advanced > Draw Setup
发表于 2005-3-26 20:55:29 | 只看该作者
多看幫助文件!
GMT+8, 2026-6-29 18:38 , Processed in 0.066953 second(s), 12 queries , Gzip On, Redis On.
