查看: 17471|回复: 2
关于UF_CURVE_create_spline_thru_pts的问题
发表于 2005-4-28 11:50:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大侠,有谁用过这个命令,
我编出了一些东西,在编译的时候没有问题,可是到运行的时候出不来我想要的图形,我想得到的结果是要经过两个点建立一条曲线
麻烦高手帮我看看,下面的代码错在哪?
   int degree=1;
          int num_points=2;
         int save_def_data=1;
   int periodicity=0;
   tag_t spline_tag;
   int i_ret;
   double x1[3]={12,23,54};
   double x2[3]={51,68,91};
   UF_CURVE_pt_slope_crvatr_t point_data[3];
   point_data[3].point[3]=12,23,54;
   point_data[3].point[3]=51,68,91;
   point_data[3].slope_type=UF_CURVE_SLOPE_AUTO;
   point_data[3].slope[3];
   point_data[3].crvatr_type=UF_CURVE_CRVATR_AUTO_DIR;
   point_data[3].crvatr[3];
              i_ret=UF_CURVE_create_spline_thru_pts (
     degree ,/* <I>degree of the spline*/
              periodicity ,/* <I>periodicity of the spline: 0=non-periodic,             1=periodic*/
              num_points ,/* <I>number of points and parameters in the             following arrays*/
              point_data ,/* <I>array of data defining points    andslope/curvature control*/
              NULL,/* <I>
                   parameters of input points. This is a user specified
                   parameterization for the input points, which needs to be
                   monotonic increasing (i.e. parameters(i) < parameters(i+1)
                   for all i), but does not need to be normalized, if NULL
                   then the default parameterization will be used.
              save_def_data ,/* <I>
                             If save_def_data = 1, save input defining
                             data with the created spline. Otherwise, no.
              &spline_tag  /* <O>
                           tag of the created spline
谢谢各位了!
发表于 2005-5-1 21:15:40 | 只看该作者
发表于 2005-5-4 10:14:46 | 只看该作者
GMT+8, 2026-8-4 11:53 , Processed in 0.048052 second(s), 11 queries , Gzip On, Redis On.
