查看: 15931|回复: 3
刀路计算完成出现这样一串警告,咋办?
发表于 2005-5-14 10:51:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* A region at coordinates X-64.749 Y-32.523 Z-41.000 is too small to mill with 'Corner Milling - All Round'
  Either reduce the 'Min. Radius' or use 'External Round'.
* A region at coordinates  X-64.749 Y-32.523 Z-41.000 was NOT milled.
  In order to prevent cutter breakage, all regions below were not calculated.
* AT X = -59.056, Y = 35.478, Z = -41.000 CONTOUR FOR MILLING OR FOR RAMP ANGLE IS SMALLER THAN PLUNGE SIZE.
  NO MILLING WILL TAKE PLACE IN THIS LAYER!!!
* AT X = 59.347, Y = 35.167, Z = -41.000 CONTOUR FOR MILLING OR FOR RAMP ANGLE IS SMALLER THAN PLUNGE SIZE.
* A region at coordinates X64.749 Y-32.696 Z-41.000 is too small to mill with 'Corner Milling - All Round'
* A region at coordinates  X64.749 Y-32.696 Z-41.000 was NOT milled.
* PROCEDURE EXECUTION END TIME    : 14/05/2005.09:31:00
* PROCEDURE VOLUME MILLING-SPIRAL CUT - 3D = 3 IS REPLACED
发表于 2005-5-14 20:03:13 | 只看该作者
发表于 2005-5-15 08:45:53 | 只看该作者
发表于 2005-5-16 17:45:51 | 只看该作者
GMT+8, 2026-8-16 19:16 , Processed in 0.053380 second(s), 11 queries , Gzip On, Redis On.
