查看: 16283|回复: 0
CAA的PDM
发表于 2005-5-19 16:47:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Before having access to the three PDM commands, you have to:
rebuild the code of the use-case
activate xPDM toolbar. To do so, follow the instruction below:
locate and edit the CAAxPDMInterfaces.edu.dico file that is located in the "code\dictionary\" folder of your runtime view
remove the comment at the beginning of the last line.
The content of the file should now look like:
# uncomment the following line to activate the xPDM toolbar
CAAxPDMAddin CATIPrsConfigurationAddin libCAAxPDMController
CAAxPDMAddin CATIPrtCfgAddin libCAAxPDMController
save the modified file.
Now the xPDM toolbar will be available the next time you launch CATIA V5.
define the "pseudo" PDM "vault" and the "work" folder. They are defined as Windows/UNIX environment variables.
On Windows, type:
set CAAxPDMVaultDir=E:\xPDM\Vault
set CAAxPDMWorkDir=E:\xPDM\Work
里面的
On Windows, type:
是什么意思?
environment variables是指环境变量吗?我在里面设置了,不行。应该如何操作。请指教!
GMT+8, 2026-8-13 01:15 , Processed in 0.066406 second(s), 10 queries , Gzip On, Redis On.
