查看: 15530|回复: 0
跪求高手帮我改改!~~我用VLISP编的
发表于 2005-5-25 12:10:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
myshaft:dialog{
label="轴的结构绘图";
     :boxed_row{
label="请选择轴的结构";
       :image_button{
color=0;
aspect_ratio=0.7;
Key=shaft_imagel;
width=25;
fixed_height=true;
:image_button{
color=0;
aspect_ratio=0.7;
Key=shaft_image2;
width=25;
fixed_height=true;
:image_button{
color=0;
aspect_ratio=0.7;
Key=shaft_image3;
width=25;
fixed_height=true;
:boxed_row{
:boxed_column{
label=" 参数输入:";
:row {
:edit_box{
label=" 轴直径D(mm) ";
Key="shaft_ D";
edit_width=6;
:edit_box{
label=" 轴长L(mm)";
Key="shaft_ L";
edit_width=6;
:row{
:edit_box{
label="倒角宽B(mm) ";
Key="chamfer_ B";
edit_width=6;
:edit_box{
label="倒角宽A(mm)";
Key="chamfer_ A";
edit"width=6;
:radio_row{
LabeL="选择轴的方向";
            :radio_button{
Key="Key_radio_Left";
LabeL="从左往右";
Value=1;
  :radio_button{
Key="Key_radio_right";
LabeL="从右往左";
Value=0;
:column{
:boxed_column{
:boxed_column{
labeL="轴的基准点(起始点):";
:button{
labeL="选择点<<";
key="pick_point";
:edit_box{
labeL="X轴坐标:";
key="start_X";
edit_width=6;
:edit_box{
labeL="Y轴坐标:";
key="start_y";
edit_width=6;
ok_cancel_help;
我编的但怎么运行不了, 出现错误我不知道怎么改啊
GMT+8, 2026-8-24 09:02 , Processed in 0.057409 second(s), 13 queries , Gzip On, Redis On.
