查看: 23363|回复: 5
Catia 的 VBA 问题 (新手问题)
发表于 2005-5-28 15:29:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Sub CATMain()
     ' 1-Prolog
     ' 1.a-Declare required variables: command set, motion matrix
     Dim dValcmd(0 To 1)  'As  ' Double
     'Dim dMotion(11) As Double
     ' 1.b-Retrieve the root product
     Dim oRootProduct As AnyObject
     Set oRootProduct = CATIA.ActiveDocument.Product
     ' 1.c-Retrieve the Mechanisms as a TechnologicalObject of the Product
     Dim cTheMechanisms As AnyObject
     Set cTheMechanisms = oRootProduct.GetTechnologicalObject("Mechanisms")
     ' 1.d-Take 1st mechanism found, and first moving part
     Dim oFirstMechanism As Mechanism
     Set oFirstMechanism = cTheMechanisms.Item(1)
     ' 2-Retrieve number of moving parts, and first one
     Dim iNbProd As Integer
     iNbProd = oFirstMechanism.NbProducts
     Dim oMovingPart As Product
     oMovingPart = oFirstMechanism.GetProduct(1)
     ' 3-Retrieve current command values
     oFirstMechanism.GetCommandValues dValcmd()
     ' 4-Solve for other command values
     ' 4.a-Create another command set
     dValcmd(0) = dValcmd(0) + 10
     ' 4.b-Apply the command set
     oFirstMechanism.PutCommandValues dValcmd
     ' 5-Retrieve motion for a part after solving and apply it
     ' 5.a-Retrieve motion for a part after solving
     oFirstMechanism.GetProductMotion oMovingPart, dMotion
     ' 5.b-Apply the motion to the part
     oMovingPart.Move.Apply dMotion
End Sub
以上程序为Catia自带程序,可是在运行时,程序停在:oFirstMechanism.GetCommandValues dValcmd()
中的GetCommandValues处,并提示:编译错误:函数或接口标记为限制的,或函数使用了Visual Basic不支持的自动化(Automation)类型。
请问各位高手,你们如何处理这个问题?
多谢!!!1
发表于 2005-5-29 18:43:55 | 只看该作者
发表于 2005-5-30 10:33:30 | 只看该作者
发表于 2005-5-30 11:30:37 | 只看该作者
发表于 2009-10-16 11:46:35 | 只看该作者
发表于 2009-10-16 17:12:40 | 只看该作者
GMT+8, 2026-8-17 08:34 , Processed in 0.050610 second(s), 11 queries , Gzip On, Redis On.
