查看: 19141|回复: 2
ug实体的复制和平移问题
发表于 2005-5-28 23:11:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近小弟做毕业设计,刚接触ug二次开发,想实现实体的复制和平移,但是函数FTN(uf5947)的返回值resp=3,不为0,不知应该怎样改正,请高手赐教,源代码如下
#include <stdio.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_curve.h>
#include <math.h>
#include <uf_modl.h>
#include <uf_trns.h>
#include <uf_part.h>
#include "create_circular_iset.h"
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
static int report( char *file, int line, char *call, int irc)
  if (irc)
     char    messg[133];
     printf("%s, line %d:  %s\n", file, line, call);
     (UF_get_fail_message(irc, messg)) ?
       printf("    returned a %d\n", irc) :
       printf("    returned error %d:  %s\n", irc, messg);
  return(irc);
static void do_ugopen_api(void)
  double DN=700,D=815,D1=780,D3=740,B=36,d=18,NUM=28,THIN=10;
  double origin[3] = {0.0, 0.0, 0.0};
  double orig_iset[3] = {0.0, -390, 0.0};
  double direction[3] = {0.0, 0.0, 1.0};
  UF_CURVE_line_t sline,sline1,sline2,sline3,sline4,sline5,sline6,sline7,sline8;
   tag_t line,line1,line2,line3,line4,line5,line6,line7,line8;
  int obj_count;
   UF_FEATURE_SIGN mode_sign=UF_NULLSIGN;
   tag_t generators[9],generators1[3],*objects;
   char *body_limit[2]={"0.0","360.0"};
   char *offsets[2]={"0.0","0.0"};
   UF_MODL_SWEEP_TRIM_object_p_t trim_data=NULL;
   char height[256];
   char diam_iset[256];
   char degree[256];
   char num[256];
   char message[133];
   UF_FEATURE_SIGN sub = UF_NEGATIVE;
   tag_t iset_id,feat_obj;
   uf_list_p_t feat_list;
   double matrix[16];
     int copy_Flag=2, layer=-1, curveFlag=2,count=3,resp;
     tag_t curve_id;
   height[0]='\0';
   diam_iset[0]='\0';
   num[0]='\0';
   degree[0]='\0';
   message[0]='\0';
   sprintf(height,"%f",B-3);
   sprintf(diam_iset,"%f",d);
   sprintf(num,"%f",NUM);
   sprintf(degree,"%f",360/NUM);
     sline.start_point[0]=DN/2;
   sline.start_point[1]=0;
   sline.start_point[2]=B;
   sline.end_point[0]=D3/2;
   sline.end_point[1]=0;
   sline.end_point[2]=B;
   UF_CALL(UF_CURVE_create_line([$sline,&line))]
   sline1.start_point[0]=D3/2;
   sline1.start_point[1]=0;
   sline1.start_point[2]=B;
   sline1.end_point[0]=D3/2+3;
   sline1.end_point[1]=0;
   sline1.end_point[2]=B-3;
   UF_CALL(UF_CURVE_create_line([$sline1,&line1))]
   sline2.start_point[0]=D3/2+3;
   sline2.start_point[1]=0;
   sline2.start_point[2]=B-3;
   sline2.end_point[0]=D/2;
   sline2.end_point[1]=0;
   sline2.end_point[2]=B-3;
   UF_CALL(UF_CURVE_create_line([$sline2,&line2))]
   sline3.start_point[0]=D/2;
   sline3.start_point[1]=0;
   sline3.start_point[2]=B-3;
   sline3.end_point[0]=D/2;
   sline3.end_point[1]=0;
   sline3.end_point[2]=0;
   UF_CALL(UF_CURVE_create_line([$sline3,&line3))]
   sline4.start_point[0]=D/2;
   sline4.start_point[1]=0;
   sline4.start_point[2]=0;
   sline4.end_point[0]=DN/2+THIN+2+3*sqrt(3);
   sline4.end_point[1]=0;
   sline4.end_point[2]=0;
   UF_CALL(UF_CURVE_create_line([$sline4,&line4))]
   sline5.start_point[0]=DN/2+THIN+2+3*sqrt(3);
   sline5.start_point[1]=0;
   sline5.start_point[2]=0;
   sline5.end_point[0]=DN/2+THIN+2;
   sline5.end_point[1]=0;
   sline5.end_point[2]=3;
   UF_CALL(UF_CURVE_create_line([$sline5,&line5))]
   sline6.start_point[0]=DN/2+THIN+2;
   sline6.start_point[1]=0;
   sline6.start_point[2]=3;
   sline6.end_point[0]=DN/2+THIN+2;
   sline6.end_point[1]=0;
   sline6.end_point[2]=13;
   UF_CALL(UF_CURVE_create_line([$sline6,&line6))]
   sline7.start_point[0]=DN/2+THIN+2;
   sline7.start_point[1]=0;
   sline7.start_point[2]=13;
   sline7.end_point[0]=DN/2;
   sline7.end_point[1]=0;
   sline7.end_point[2]=13+(THIN+2)/sqrt(3);
   UF_CALL(UF_CURVE_create_line([$sline7,&line7))]
   sline8.start_point[0]=DN/2;
   sline8.start_point[1]=0;
   sline8.start_point[2]=13+(THIN+2)/sqrt(3);
   sline8.end_point[0]=DN/2;
   sline8.end_point[1]=0;
   sline8.end_point[2]=B;
   UF_CALL(UF_CURVE_create_line([$sline8,&line8))]
   generators[0]=line;
   generators[1]=line1;
   generators[2]=line2;
   generators[3]=line3;
   generators[4]=line4;
   generators[5]=line5;
   generators[6]=line6;
   generators[7]=line7;
   generators[8]=line8;
   UF_CALL(UF_MODL_create_revolution(generators,9,trim_data,body_limit,offsets,
    origin,false,true,origin,direction,mode_sign,[$objects,&obj_count))]
   UF_free(objects);
  UF_CALL(UF_MODL_create_cyl1(sub,orig_iset,height,diam_iset,direction,
                      [$iset_id))]
  UF_CALL(UF_MODL_create_list([$feat_list))]
  UF_CALL(UF_MODL_put_list_item(feat_list,iset_id));
  UF_CALL(UF_MODL_create_circular_iset(0,origin,direction,num,degree,feat_list,[$feat_obj))]
  UF_CALL(UF_MODL_delete_list([$feat_list))]
  generators1[0]=*objects;
  generators1[1]=iset_id;
  generators1[2]=feat_obj;
     FTN(uf5943)(orig_iset,matrix );
    FTN(uf5947)(matrix,generators1,[$count,&copy_Flag,&layer,&curveFlag,&curve_id,NULL,&resp)]
    UF_UI_open_listing_window();
  sprintf(message,"resp=%d,*objects=%d\n",resp,*objects);
  UF_UI_write_listing_window(message);
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int param_len)
  if (!UF_CALL(UF_initialize()))
    do_ugopen_api();
    UF_CALL(UF_terminate());
int ufusr_ask_unload(void)
  return (UF_UNLOAD_IMMEDIATELY);
发表于 2005-5-29 09:41:37 | 只看该作者
发表于 2005-5-29 11:29:52 | 只看该作者
GMT+8, 2026-8-4 12:50 , Processed in 0.056899 second(s), 13 queries , Gzip On, Redis On.
