查看: 15668|回复: 0
急问,那位大侠告知怎样在UG用程序创建扫描体?
发表于 2005-6-1 16:51:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下是实现的代码,不能创建成功,那位大侠指点一二??急盼!!!!!
首先,我通过程序画出了5条截面线和3根导线,然后做了一个扫描实体的程序代码,拷贝如下,请各位大虾帮忙找问题:
  /*[说明]:扫描创建实体
  UF_MODL_init_string_list([$s_guide)]
  UF_MODL_create_string_list(3,3,[$s_guide)]
  s_guide.num = 3;
  for(i=0;i<3;i++)
    s_guide.string = 1;
    s_guide.dir = 1;
    s_guide.id = guideLine_tag;
  UF_MODL_init_string_list([$s_section)]
  UF_MODL_create_string_list(5,5,[$s_section)]
  s_section.num = 5;
  for(i=0;i<5;i++)
    s_section.string = 1;
    s_section.dir = 1;
    s_section.id = spline_tag;
  alignment = 1;//Alignment method:
    = Parameter
    = Arc Length
  inter = 2;//Interpolation method (for s_section->num > 1):
    = Linear
    = Cubic
  body_type =0;//Type of body:
                  = Sheet (Default)
    = Solid
  boolean =UF_NULLSIGN;//The sign of the operation to be performed.
                         // UF_NULLSIGN = create new target solid
             //UF_POSITIVE = add to target solid
             //UF_NEGATIVE = subtract from target solid
             //UF_UNSIGNED = intersect with target solid
  //Tolerances:
  tol[0] = 0.025;//[0] = Distance
  tol[1] = 0.2; //[1] = Angle (in radians)
  tol[2] = 0.1; //[2] = Intersection
  UF_MODL_create_sweep(&s_guide, //UF_STRING_p_t s_guide,
     &s_section, //UF_STRING_p_t s_section,
             NULL, //UF_STRING_p_t s_spine,
             NULL, //UF_METHOD_p_t orientation,
             NULL, //UF_METHOD_p_t scaling,
             &alignment, //int * alignment,
             &inter, //int * inter,
             &body_type, //int * body_type,
             boolean, // UF_FEATURE_SIGN boolean,
             tol, //double tol[ 3 ],
             [$body_obj_id)]//tag_t * body_obj_id
GMT+8, 2026-6-12 19:44 , Processed in 0.077118 second(s), 11 queries , Gzip On, Redis On.
