查看: 15770|回复: 4
仿真问题
发表于 2005-6-8 19:13:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位高手:我在adams/view中建立的汽车悬架模型,出现以下警告,不知什么原因。望帮帮小弟。谢谢!
WARNING:    An anomalous situation has been detected for TIRE b_jeep.TIRE_1.
   The moment arm for normal force (Fz) that causes the
   rolling resistance moment (Ty) is greater than the allowable
   maximum of 1/2 the length of the contact patch.
   CRR = 5.6250
   CRR_max = 2.36568E-02
WARNING:    For TIRE b_jeep.TIRE_3 the absolute value of the longitudinal slip ratio
   has gone beyond its maximum allowable limit of 1.0.
   Longitudinal slip ratio = 4.97331E+06.
   If the longitudinal slip ratio is positive, it will be set
   to 1.0 (braking).  If the longitudinal slip ratio is
   negative, it will be set to -1.0 (traction).
发表于 2005-6-8 20:38:42 | 只看该作者
发表于 2005-6-9 16:28:50 | 只看该作者
发表于 2005-6-10 08:31:29 | 只看该作者
发表于 2005-6-11 10:03:57 | 只看该作者
GMT+8, 2026-8-2 12:08 , Processed in 0.052953 second(s), 11 queries , Gzip On, Redis On.
