查看: 16253|回复: 2
Proe_mold Shrinkage
发表于 2005-6-10 07:55:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位高手:
我每次在Proe中设置缩水后它总是报告"Accuracy Conflict",然后生成一个
.acc后缀的文件,打开后如下,请问如何解决这个问题?
Accuracy Conflict Report For Assembly CASTING_MOLD.
1. Models in the list may have accuracy set to absolute or relative accuracy.
2. When the model's accuracy is relative, an absolute accuracy value
is calculated based on the model's relative accuracy.
3. The following list shows the absolute accuracy value for each model
that is actually used in geometry calculations.
     Generic Model Name                Abs Accuracy Value  Unit Name
CASTING_MOLD.ASM                      0.020802821          mm
CASTING_MOLD_REF.PRT                0.014426095          mm
CASTING_WRK.PRT                        0.021655542          mm
发表于 2005-6-29 16:05:17 | 只看该作者
发表于 2005-6-30 08:10:31 | 只看该作者
GMT+8, 2026-8-20 22:22 , Processed in 0.052176 second(s), 11 queries , Gzip On, Redis On.
