查看: 15717|回复: 2
分析中出现的问题
发表于 2005-6-14 13:44:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
** WARNING 701360 ** Beam element   35600  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36103  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36104  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36105  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36106  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36107  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36108  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36109  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element   36110  has a very bad length/diameter ratio
** WARNING 701380 ** Warnings were reported in the model
                     Check the mesh quality of the model
请各位大哥帮忙,这是怎么回事,谢谢
发表于 2005-6-14 16:05:57 | 只看该作者
流道或水路的单元划的太密了,控制长径在3.0左右。
发表于 2005-6-14 17:10:02 | 只看该作者
谢谢你。
GMT+8, 2026-4-29 13:38 , Processed in 0.054528 second(s), 11 queries , Gzip On, Redis On.
