查看: 16490|回复: 2
用UF_MODL_ask_mass_props_3d求体积的问题
发表于 2005-8-12 09:26:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用UF_MODL_ask_mass_props_3d求一个正方体(边长100)的体积时,返回值是61~~!
mass_props[1]是volume~~!
下面是代码:
  int rcode = UF_UI_lock_ug_access(UF_UI_FROM_CUSTOM);
   if(rcode != UF_UI_LOCK_SET)
     AfxMessageBox("failed to lock");
     return;
   char *message = "请选择实体";
   char *title = "选择实体";
   int response,sel_count;
   tag_p_t sel_objects;
   int retn = UF_UI_select_with_class_dialog(message,title,UF_UI_SEL_SCOPE_NO_CHANGE,
     NULL,NULL,[$response,&sel_count,&sel_objects)]
   if(retn == 0)
     if(response == UF_UI_OK && sel_count>0)
       objects = sel_objects;
       count = sel_count;
   else
       AfxMessageBox("ret != 0");
   rcode = UF_UI_unlock_ug_access(UF_UI_FROM_CUSTOM);
   if(rcode != UF_UI_UNLOCK_SET)
      AfxMessageBox("failed to unlock");
   //计算体积
   int type = 1;//solid body
   int units = 1;
   double density = 1;
   int accuracy = 1;// Use Accuracy
   double acc_value[11] = {1.0,0,0,0,0,0,0,0,0,0,0};
   double  mass_props[47];//output
   double  statistics[13];//output
   int ret = UF_MODL_ask_mass_props_3d(objects,count,type,units,density,
     accuracy,acc_value,mass_props,statistics);
   if(ret == 0)
     CString volume ;
     volume.Format("%.1f",mass_props[1]);
     SetDlgItemText(IDC_VOLUMEEDIT, volume);
   else
     AfxMessageBox("计算体积错误!");
发表于 2005-8-12 09:40:53 | 只看该作者
发表于 2005-8-12 09:59:21 | 只看该作者
GMT+8, 2026-8-4 12:50 , Processed in 0.076241 second(s), 11 queries , Gzip On, Redis On.
