查看: 16485|回复: 4
UF_CSYS_ask_matrix_of_object?请键盘兄看看
发表于 2005-8-18 21:22:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
static void do_ugopen_api(void)
    char cue[] = "Select Objects";
    char title[] = "User Title";
    int response, count, i;
    tag_p_t objects;
  tag_t matrix;
  double values[9];
    /* Use multiple class selection with scope set to any object
       in the work part and without using an initialization procedure.
    if((UF_CALL(UF_UI_select_with_class_dialog(
          cue, title, UF_UI_SEL_SCOPE_WORK_PART,
          NULL, NULL, &response, &count, &objects))) == 0)
         printf("object count = %d\n",count);
         if (response == UF_UI_OK && count > 0)
             for (i=0; i<count; i++)
                 printf("object tag = %d\n", objects);
                 UF_DISP_set_highlight(objects, 0);
    UF_CSYS_ask_matrix_of_object(objects[0],[$matrix)]
    UF_CSYS_ask_matrix_values(matrix,values);
        UF_free(objects);
  UF_UI_open_listing_window();
  for(i=0;i<=9;i++)
    sprintf(buf,"%f\n",values);
    UF_UI_write_listing_window(buf);
出来的数值:
-92559631349317831000000000000000000000000000000000000000000000.000000
-92559592117431994000000000000000000000000000000000000000000000.000000
不知道哪里错了
发表于 2005-8-18 21:54:42 | 只看该作者
发表于 2005-8-18 22:26:51 | 只看该作者
发表于 2005-8-19 11:26:24 | 只看该作者
发表于 2005-8-20 09:28:30 | 只看该作者
GMT+8, 2026-8-4 11:32 , Processed in 0.100109 second(s), 10 queries , Gzip On, Redis On.
