查看: 20263|回复: 35
NX4.0新增功能(cam部分)
发表于 2005-8-26 02:45:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
what' new in NX4.0 beta:
部分内容:
1.Save Tool to NX Library 保存刀具到刀具库
Saving an existing tool is much easier than adding a tool to the ascii library using a text editor.
这个不象以前那么麻烦,要输出ASCII。。。
2.Automatic Gouge Check Before Postprocessing 后处理之前自动过切检查
Turn this setting on to guarantee that only gouge-free operations are postprocessed
会这么智能?
3.Plunge Milling 插铣
Plunge milling can be more efficient than cavity milling when machining large amounts of material, especially in very deep areas. The reduced radial force makes it possible to use long slender tools and maintain a high rate of material removal. This makes plunge milling attractive for finishing hard-to-reach deep walls.
这就是大家盼望已久的插铣?
4.Face Milling Undercut Handling 平面加工底切处理
这也是大家所期盼的吗?
5.Contour Profiling 轮廓铣
有两种选项:Follow Wall Bottom 和Auxiliary Floor.
发表于 2005-8-26 09:56:28 | 只看该作者
发表于 2005-8-26 11:17:26 | 只看该作者
发表于 2005-8-26 14:48:31 | 只看该作者
发表于 2005-8-26 19:52:34 | 只看该作者
发表于 2005-8-26 22:02:05 | 只看该作者
发表于 2005-8-26 22:14:59 | 只看该作者
发表于 2005-8-26 22:37:28 | 只看该作者
发表于 2005-8-27 10:36:33 | 只看该作者
GMT+8, 2026-8-20 03:21 , Processed in 0.113435 second(s), 11 queries , Gzip On, Redis On.
